TURBO WONT FIT!!!!!!
Old Dec 3, 2009 | 06:19 PM
Hoe Hopper's Avatar
Default TURBO WONT FIT!!!!!!
Hey guys im currently in the process of installing my t3/t40e on my d16y8 but when i tried to mount everything on, my turbo is hitting the web casting on my motor. I was just wondering if it was okay if i took a grinder and cut a little off or would that weaken my motors structure? The part its touching is under my exhaust manifold to the left right before the tranny. Is this common or should i look for a new manifold, i currently have a spoolin log mani.
Old Dec 3, 2009 | 06:23 PM
MiraiZ's Avatar
Default Re: TURBO WONT FIT!!!!!!
A lot of people have this problem...just take a dremel or grinder and cut a notch in it
Old Dec 3, 2009 | 06:25 PM
hickle's Avatar
no, if its just extra metal you can grind off to make room without really getting into anything you should be fine.
Old Dec 3, 2009 | 06:57 PM
mattyfo0z's Avatar
Pretty much. Just a small notch will do. Make sure you don't cut into the block, obviously
Old Dec 3, 2009 | 07:16 PM
Hoe Hopper's Avatar
Cool.....thanks guys.
Old Dec 4, 2009 | 04:42 AM
dpetro1's Avatar
pics of said set-up? is your turbo 4-bolt or 5-bolt? i was under the impression that the spoolin log mani spaced the turbo away from the block.
or do you have the spoolin "cast" mani. in that case some notching is required and perfectly normal for our cars.
Old Dec 4, 2009 | 04:54 AM
Hoe Hopper's Avatar
Its a spoolin cast log manifold...I wish I can show a picture but I'm on phone. The turbo is a t3 t4 and it looks like I need to grind from where the tranny and block meet but I'm worried that I might grind into something critical. I have a spare blown block so I'm gonna do a test on that first and see what happens.
Old Dec 4, 2009 | 05:00 AM
dpetro1's Avatar
ok that makes more sense. now the big question is 4 or 5-bolt turbo. if its 4-bolt you are gonna have major clearance issues and it may not fit at all, even after notching. cast manis are designed to work with 5-bolt turbos.
if you have a 5-bolt then notch it and you are good to go. here's a pic for reference
Old Dec 4, 2009 | 05:05 AM
Hoe Hopper's Avatar
Its a 5 bolt and see that bump right next to where he notched it...that's where I have to grind but I don't know what's behind it.
Old Dec 4, 2009 | 05:08 AM
Hoe Hopper's Avatar
And that's a b series mines is a d it looks different
Old Dec 4, 2009 | 05:13 AM
dpetro1's Avatar
im sure you will still be fine, there is plenty of meat at the engine stamp area. dont be scurred!
Old Dec 4, 2009 | 05:14 AM
Hoe Hopper's Avatar
Well just have to find out
Old Dec 4, 2009 | 07:58 AM
93CX's Avatar
I had to cut the **** out of my B16 block to fit my spoolin log
Old Dec 4, 2009 | 08:18 AM
dpetro1's Avatar
cast or tubular? 4 or 5-bolt turbo? my guess is cast w/ a 4-bolt...
Old Dec 4, 2009 | 01:49 PM
miguel329's Avatar
yea theres alot of metal around the stamp area ... i help a friend do that and there was barely a stamp left... i just got decent manifold that i didnt need to do that....
Old Dec 4, 2009 | 10:45 PM
Hoe Hopper's Avatar
Well after grinding the **** out of it....it fit like a charm...thanks guys for all the help.
Old Dec 4, 2009 | 11:17 PM
t3601's Avatar
you could have just turned the turbo the other way so the compressor is on the driver side. then you don't have to hack at your block. unless your tryin to run a/c also.
Old Dec 5, 2009 | 10:35 AM
dpetro1's Avatar
true but i assume he already has all of his parts. flipping the turbo would require mods to the downpipe, ic piping, maybe oil return and dumptube too
glad to hear. happy boosting
Fc_v8
Sep 21, 2010 01:01 PM
GSROWNSU
Jul 14, 2008 01:48 PM
BOOSTEDgs-R
Feb 17, 2008 04:00 PM
Integra808
Apr 15, 2003 06:18 AM
98civicEX
Jun 25, 2002 05:01 AM
