Need all info possible on installing an b18b in 1st gen crx si!!!!!!``
Old Sep 2, 2002 | 08:07 AM
Acura_I-RS's Avatar
Default Need all info possible on installing an b18b in 1st gen crx si!!!!!!``
well, im selling my integra, and getting a 87 crx si, and plan on dropping in a built b18b ls motor, but i wanna know if anyone has ever done this before, what all i will need. i know i will need the wiring harness, ecu, axles, tranny. but which mount kits are the best for this swap, and i dunno, i just need some help, thanks a lot, later-justin
Old Sep 2, 2002 | 10:41 AM
Losrocket_'s Avatar
Default Re: Need all info possible on installing an b18b in 1st gen crx si!!!!!!`` (Acura_I-RS)
HASport makes the mount kit for any B series into an 84-87. They also sell the shift linkage and Ecu. http://hasport.com/ I had B20vtec in my old '87 HB and it was fast but it wasnt built so if your gonna put a built LS in I can only imagine the power that little *** cars gonna have
Old Sep 2, 2002 | 03:51 PM
Acura_I-RS's Avatar
Default Re: Need all info possible on installing an b18b in 1st gen crx si!!!!!!`` (Losrocket'91)
do u know if it is a pretty easy swap? like what kind of problems do people encounter while doing it if you know, just trying to save myself a few headaches i guess, thanks, oh, wheres the best place to get the hasport mount kit???
Old Sep 2, 2002 | 04:06 PM
EF_LSVtec's Avatar
One of the problems I encountered is getting the wrong intermediate shaft, or I was given the wrong one. Another one is getting the pins out of the ECU...I had to order the pin-tool from Hasport and have them ship it overnight. A regular paper clip usually works, but 2 of the pins wouldnt come out. Besides that, once the motor was in, everything else just dropped in to place...I was pretty close to a local Automotive shop too, so getting bolts, hoses etc. was quick. It'll be nice to clean your engine bay too and prep it before dropping the new motor. Check out http://www.hasport.com
Old Sep 6, 2002 | 01:59 PM
Acura_I-RS's Avatar
Default Re: Need all info possible on installing an b18b in 1st gen crx si!!!!!!`` (EF_LSVtec)
why do u have to remove the pins from the ecu??? i plan on getting the whole motor, ecu, wiring harness and everything, can u explain that???
suprakhmer96
Apr 19, 2005 06:04 AM
VTECepidemic
Jan 28, 2005 12:46 PM
mugenek007
Nov 2, 2004 04:50 PM
95hbMatt
Jun 17, 2002 12:35 AM
Duck Sauce
Dec 3, 2001 09:27 PM
