valve seals... ?
Old Dec 2, 2009 | 10:10 PM
forsakenriceboy86's Avatar
Default valve seals... ?
when replacing/installing new valve seal, how would YOU! install them.? pushing it in with a 11mm or 12mm until there's a click.? giving it a soft tap.?
thank you.!..
Old Dec 3, 2009 | 07:38 AM
Default Re: valve seals... ?
any suggestions or option.?
Old Dec 3, 2009 | 07:41 AM
Hybrid96EK's Avatar
You shouldn't need to tap them on at all. They will simply click. I lube them with a touch of oil to help prevent galling of the inside. Thats all. Never had a problem. I think the socket I used was an 11mm if I recall correctly, been a while.
Old Dec 3, 2009 | 08:55 AM
DSRxCandyh2bEG's Avatar
x2
or just use your thumb to press it down after a while your thumb might get sore though...
Old Dec 3, 2009 | 04:36 PM
hAhAa... lUbey and clicky it is and seems like its the best then.! im working on my first build and i wanted to know how everyone usually do theirs...
Hybrid96EK, DSRxCandyh2bEG <thanks dUdes...
mithious
19
Apr 21, 2015 03:23 PM
Atomic1
Mar 27, 2010 08:57 PM
s.cha
Jan 29, 2010 05:10 AM
Kr4nG
Nov 2, 2009 01:53 PM
1.8EG-T
Dec 14, 2003 02:56 PM
