bad catalyst convertor?
so i just got my cat replaced for an aftermarket high flow cat from magnaflow... i realized that i am burning oil...like a lot too..probably from a valve stem seal leak becuz i did a compression test and a leak down test and it all seems fine. It has only been like 2 weeks and im startin to smell a rotten egg smell? Does that mean my catalyst convertor went bad already?
My car is a 96 integra with a obd1 ls vtec motor...
What could be the problem?
horrible...like 20ishh a gallon.. but i just put the cat on? i was running an itr one before this, but since i just got the apexi ws2 i upgraded 2.5 piping and a highflow cat and thats when i started to smell the rotten egg. Is that what a bad cat smells like though?
yikes...anyone have a rebuild thread or a check off list that they used? i just picked up the stage 2 cams springs and retainers today for 400 ..!! probably gonna need rings, bearings, and all the bs gaskets?
If anyone has their build check off list, that would greatly be apperciated.
mortificationrock
12
Jan 28, 2010 12:09 PM
