Suspension & Brakes Theory, alignment, spring rates....
Brake problem on my DA need help
Old Dec 2, 2009 | 07:20 PM
bonspeed's Avatar
Default Brake problem on my DA need help
recently i got a '92 RS DA.. but it was stocked for i think almost 2 years, so all the brake calliper's and rotors are rusted but now it's all cleaned and working(but not working good) the front right brake stocks a bit and the rear left too.. my problem is when i step on the brakes slowly it goes all the way down the floor but when i step on it a bit hard it acts normal and stops normal too.. could it be the brake master or should i bleed more the brakes?...
TIA!
Old Dec 9, 2009 | 05:38 PM
projectTeG's Avatar
Default Re: Brake problem on my DA need help
master cly. or a leak, you loosing fluid?
Old Dec 10, 2009 | 01:10 AM
flip_nl's Avatar
Also did you refreshed the brake fluid, could not make clear if you did it or not.
Brakefluid is hydrophilic, so it need to be changed within time.
Bleed more the brakes? No air in the system would be my first concern, if there was a steady stream of fluid with no air bubbles it should be good.
jdmjoka
Dec 16, 2008 06:31 PM
tazz29
Jul 9, 2008 10:52 AM
Bizarre
Feb 5, 2005 04:42 PM
bOOsTiNSoHcVtEc
May 11, 2004 12:55 PM
sacredc0w69
Apr 29, 2003 11:05 AM
