car bogs when throttle
Old Dec 2, 2009 | 04:37 PM
thundernutz's Avatar
Default car bogs when throttle
ok i have a 91 civic with a 0bd1 conversion. i am throwing code 5,9 when i start the car it barly runs. but i can give it gas and it will throttle up but after about 30 sec it kicks over and sounds and runs like it should. and starts but if i hit the throttle it bogs and dies any ideas all my wire is rite but when i throttle the lights flicker any ideas wold be great thx
Old Dec 2, 2009 | 05:02 PM
Boost_Addict_88's Avatar
Default Re: car bogs when throttle
I don't know Honda codes, but it sound like a bad injector (or possible injector wiring). Pull each injector and make sure that they're spraying correctly. Check your fuel filter as well (maintenance). If those fail, then check your fuel pump.
By the way, have you done any maintenance lately, such as plugs and wires?
Old Dec 2, 2009 | 06:08 PM
frank_el_tanke's Avatar
what engine setup are you running? are you using the map sensor on your firewall?
Old Dec 2, 2009 | 08:08 PM
Eks_86's Avatar
code 5 is MAP sensor en code 9 is CYP sensor
Old Dec 2, 2009 | 08:24 PM
popwars123's Avatar
i know this sounds weird, but check your fuses and make sure that they are all the proper size fuses, ive seen having a 7.5 fuse in a 15 do this before.. can tremember which circuit it was for though.
Old Dec 7, 2009 | 07:05 AM
Eks_86's Avatar
bump
Demonvw
Honda Civic (2006 - 2015)
Jul 1, 2018 09:30 AM
93sidelsolvtec
Jan 25, 2007 05:37 PM
SuzukaBlueAP2
Oct 16, 2003 02:39 PM
turboxsi
Jun 18, 2003 01:28 AM
civic1990si
Jan 21, 2003 07:52 PM
