Dome light issue...
Old Dec 2, 2009 | 01:24 PM
Aftermath_Hatch's Avatar
Default Dome light issue...
This is what I got,my dome light works fine when in the on pos. , but does not work when the doors are open. Now I've already changed the door pins from Honda about 6 months ago worked fine since and checked fuses there fine.So kinda of at a lost what it could be.
1.Dome light has power,no blown fuses.
2. New doors pins
The door trigger is a negtive switch so comes on when it sees ground,so how could it lose ground if the dome light still works? Can anybody that might of had this problem can help? Thanx
Old Dec 2, 2009 | 01:59 PM
4drEF's Avatar
Keyboard Humorist
Default Re: Dome light issue...
Ground out the wire at the door pin and it should make the light come on.
It probably won't though so you will have to trace your wiring to the light and fix it.
John Anderson
13
Mar 30, 2012 06:44 PM
Sonia's Driver
Jan 20, 2011 12:57 PM
phoenix_iii
10
Mar 15, 2006 06:20 PM
EFSiR
Jun 1, 2003 03:12 PM
