quick question.....
does anyone know the stock ride hieght of out efs? im looking into lowering springs and i have coilovers on now. they are too stiff. so im looking fro more confort. thanx!
i checked my dads stock HB before adjusting my coil overs and from the ground to the top of his wheel well it measured:
Front 24inches
Rear 24.5 inches
not sure if this helps, but i set my coilovers to 23 and 23.5
Chorizo i just traded my green neuspeed springs for the ground controls. if your in northern Cali you might still be able to get them. but you would have to swap them out of my buddies car
Front 24inches
Rear 24.5 inches
Ok I measured mine and I'm at 22in front and back,but I have 14" wheels. So if I put 15" on would the hieght change? Also I was looking at the nuspeed yellows
im only looking to trade my sprint springs for other springs or coilovers....im not looking to buy...!!!
Depends what profile the tyre is. As a general rule, the larger the diameter of the wheel, the lower the profile on the tyre to keep the same rolling distances (and the same ride height)
I'm really not trying to sound like a *****...It would really help others find information like this in the future if you included the actual question in the thread title.
btw, what shocks are you using now?
Lol ^ I'm using a weird shock set up. I'm using ek front and rear shocks. With the forks modified to fit and aftermarket rear lower control arms
btw did you find out the info on them coilovers...!!!
