rattles?
So as i was driving my car today i noticed that my header heat shield was rattling, in my head i was thinking i can just remove it like most people i have seen do it, and im a noob with cars so can anyone tell me if i should remove it or not? and if i don't what the problem might be?
The rattle you are hearing is probably the catalytic converter heatshield. It can be removed OR you can do the cat hoseclamp mod like I did on my 2000 Civic EX
Buy four hoseclamps and open them up
then attach them together like this
then wrap each clamp around the cat like so..
took off my cat heat shield & my header shield
honestly there is no difference, or at least enough to make a large amount of difference
sure there is more heat released, but unless you're running boosted its nothing to worry about - yank that **** out and call it weight reduction
98R-1144
Jun 13, 2006 02:01 PM
