header?????????
header?????????
i just put on a new header and the seal donut in between the cat and the down pipe skweeks when i hit bumps. is there any thing i can put on it to stop the skweeking?
header?????????
ok i have another question. on top of that the heat shield on the cat and the heat shield over the cat are making a bunch of noise when im siting at a light do you think i'll be alright with out them? or will it fry **** under my car?
Re: header????????? (94hondacivicvtec)
Had that exact same problem...it's quit possibly the most anoying thing when your sitting at a light...but removed mine with no problem...
Re: header????????? (MR.johnson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MR.johnson »</TD></TR><TR><TD CLASS="quote">smear some "make-a-gasket" on it and put it back on.
works every time. </TD></TR></TABLE>
Yeah, that **** works well.
I use it when taking a TB or IACV off and the gasket tears on an old car in case it doesn't seal back up to prevent a vacuum leak.
S2KILLA
09-15-2005 07:45 AM
