obd2 b16a into a DX EK...
Old Nov 29, 2009 | 10:57 PM
maximusmda's Avatar
Default obd2 b16a into a DX EK...
ok so i just ordered a b16a OBD2 complete swap from hmotors online to swap into my 98 DX coupe.... everything should mount up just fine... only problem is the wiring.. what will i need to add? ANYONE to help would be great.. please don't flame i'm a noob when it comes to swapping a motor into an ek... Thanks in advance.
Old Dec 1, 2009 | 03:22 AM
maximusmda's Avatar
Default Re: obd2 b16a into a DX EK...
anyone?
Old Dec 1, 2009 | 05:06 PM
pakn-heat's Avatar
I'm not a pro at swaps,but u can just get a ex wire harness and use that.hopfully u got the same obd as your car.
Obd2a 96-98-----use a 96-98 civic ex harness
Obd2b 99-00----use a civic si harness and maybe use civic ex harness
If you use and ex/si harness get a ecu jumper to run obd1 reason because your dx has both 02sensors on the harness and the ex/si has 1 on the harness and 1 underneath the body of the car(ran seperate).
Those should be plug n play.
U can modify yours,I think gota wire vtec,knock,pressure sensor.not 100 percent sure, but its somthin like that.
Oh and u gotta relocate o2 because dxs are on the upper part of the manifold.and b series has 1 up top and 1 on bottom. Also I think its the iac or somthing u gotta covert from 2 wire to 3 wire or it may be 3 wire to 2 wire..can't remember.
I would use civic ex harness if u can get your hands on one,,obd2(a or b) ecu jumper and get chipped ecu(obd1)
Old Dec 1, 2009 | 05:11 PM
pakn-heat's Avatar
There's a write up on how to do the swap exactly, somewere on here.maybe in faq's.
If not google it up.it should show up.
Old Dec 1, 2009 | 10:08 PM
maximusmda's Avatar
thanks for the advice.. i googled this crap out of it! lol i'm pretty sure i'll be alright.. ill figure **** out.. i'll end up modifying my dx harness cause i dont really wanna deal with the 1 o2 sensor thing from the ex/si harnesses... and yes i got the obd2 SIRII..
Old Dec 2, 2009 | 07:11 AM
pakn-heat's Avatar
Or if u don't feel comfortable doin the wiring.go to rywire.com they can hook. U up.
Old Dec 2, 2009 | 07:59 AM
Mr_ET's Avatar
wiring should be easy even with the dx harness all you need is to add wires for vtec, knock sensor and extend the injector wires.
If it's the same OBD I believe the IACV should be the same as well if not then convert from 3 to 2 wires, that may also need an extension.
The EX harness would make life easier if you have the funds though.
As far as bolting the engine in you will need the following from a 94-01 MT teg:
Shift linkage
axles
half shaft
rear transmission bracket
If you want P/S you will need the pump from a 99-00 SI, if you want A/C you will need the front torque mount bracket from a CRV to fit your d series a/c compressor bolt pattern.
Finally you will need the little engine mount post that goes under the timing belt cover from a 99-00 si so it works with your stock driver side mount.
Have fun!
reddcoupe
May 28, 2012 04:46 AM
splatterpaintdc
Mar 31, 2010 06:12 PM
xasiansupermanx
Oct 31, 2007 05:51 AM
hmtcrxsir
40
Sep 21, 2007 06:21 PM
CB_ejcoupe
Jun 5, 2003 11:28 PM
