random backfire?
Old Nov 29, 2009 | 11:43 AM
dangercartjason's Avatar
Default random backfire?
so like, at random, when i shut my car off, after its off for 2 to 3 seconds, it backfires, and sounds like a 22 shooting. but it only does it once in a while? suggestions?
Old Nov 29, 2009 | 01:29 PM
h22 civic's Avatar
Default Re: random backfire?
Aem. Coil on plug??
Old Nov 29, 2009 | 04:59 PM
Scott_Tucker's Avatar
You have an old CRX so I'm assuming it's carbureted? Is your idle too high or is the engine running extremely rich? The only way what you are describing will happen is if fuel gets in the exhaust after the engine is shut off.
Old Nov 29, 2009 | 08:04 PM
my idle IS a little high..its about 1100, and i think i am running rich, and ill be completely honest, im not that familiar with carburetors, so its possible that i have a vacuum line mixed up, causing it to run rich. other than vacuum, is there any other causes that could be making it run rich?
Old Nov 29, 2009 | 08:36 PM
There are a lot of things that can cause it to run rich but you need to get your idle speed down first and see if it fixes it. Is your choke coming off after the engine warms up?
turbotime
Jun 22, 2006 04:43 PM
WONG FRIED RICE
Acura TL, RL & ZDX
Jan 8, 2006 05:39 PM
goofball123321
12
Sep 14, 2004 07:34 PM
DC2*Integra
Mar 11, 2004 11:45 PM
FDeez
Jan 1, 2003 03:08 PM
