1998 integra whistle noise
I have a 1998 integra gsr with a b16 and a pro series intake manifold. While driving no matter what gear i am in at a ceartain throttle position i hear a whistle that sounds like a turbo, but i have no turbo. It doesnt happen in nuetral, only when im moving and in gear. Please help.
If the whistle noise is coming from your intake, there's nothing wrong. It natural for the intake to whistle sometimes if the noise is coming from your intake. I went through two set of different intake and both made the whistle noise.
yea i know that, but if it were the intake whistleing then wouldnt it whistle while the throttle was being pushed while the car was in nuetral? Thats why i cant test it sitting in my driveway. lol
ok its not exhaust leak and it has nothing to do with a intake manifold or the intake. beacuse i had a 98 gsr and i had a same problem which i posted a while back a go. i had stock intake stock echaust system. dont think somthing is wrong with your motor too beacuse thats what i though my mechanic did leak down test and comparison test and my motor was perfect. whatever it is its not a big deal.
this may sound really weird but turn off your radio and go for a spin! sometimes certain head units make a high pitched noise like a whistle. it only happens when your driving. im not sure why but it does happen.
lol, i already gave that a shot. Thanks for the response though
It's the stock throttle body, and it's 100% normal and OK. The stock airbox muffles the sound, so it isn't noticeable until you put an aftermarket intake onto the car. My GSR does this also, and if you look around you'll find that most others do also.
The reason you can't hear it while parked is because the engine isn't under enough load to have the throttle at that position for long enough to sustain the whistle.
Check your exhaust for one of these? (sorry I had to)
http://www.youtube.com/watch?v=eSOSJ68xOBA
HAHHAHAHHAH! WOO WOOO!!! only in the mornin only in the mornin..you supposed to be up cooking breakfast in the morning...its like an alarm clock.
dude...IT'S YOUR INTAKE/THROTTLE! The whistle occurs when you open the throttle by PUSHING the accelerator. The combination of high suction and a small throttle creates the noise. If you have a friend, tell him to play with the throttle in neutral, pop open the hood you'll hear it.
Because I had a stock intake system on my car and the car was making the whistle noise still so I know for a fact it wasn’t the intake my friend. Here is the picture
dude dont worry about lol sorry man it has to be your airbox/intake/throttle body your getting worked up over nothing this very common my integra did it at about 4200 rpms and I could hold it there so it made this noise
It's your intake. And for some reason, no it wont make the whistle while it's in neutral.
I got bigger cams so now I can't hear the whistle...
it seems like you intake doesnt look like a GS-R...it looks like a LS intake! did you check your intake manifold gasket or your throttle! cause my GS-R has a short ram intake that blows like turbo...its running fine and strong?
crxtreme27
Aug 31, 2002 11:49 AM
