Looking at this turbo kit what do you guys think?
Old Nov 27, 2009 | 01:57 PM
alejo98cx's Avatar
Default Looking at this turbo kit what do you guys think?
http://vancouver.en.craigslist.ca/rd...482812421.html
Not much to say, its for a stock 98 Cx Hatch, may be building the bottom end later on or if I run into some money before I get to putting this thing on then i'll build the bottom with the kit. You guys see any problems with this?
Not looking for crazy power, I am pretty sure I will be more than happy with 200Whp(more you get more you want), may take it to the strip but more interested in taking it to the track.
Also im probably going to get a Y8 intake manifold and Maybe Maybe do a mini-me but the main reason I am going turbo is because I dont want to **** with my wiring.
I was hoping to go H22 but who am I kidding, im broke and young I want a turbo
Anyone running this turbo? How does it spool with a D16 does will it hold power to redline
anyone else got a better deal?
Old Nov 27, 2009 | 07:25 PM
912's Avatar
912
Default Re: Looking at this turbo kit what do you guys think?
id piece a better kit together, with a t3 flange, not dowing that turbo you want more power, that mani terrible and flang limits you on turbo choices, just me
Old Nov 27, 2009 | 11:26 PM
thumper64's Avatar
piece a kit together. That's way too much for what you'd get. You can find a decent T3 for fairly cheap, ebay manifold, intercooler, bov, wastegate, piping... DSM 450s, tune on crome...
I'm taking the uber cheap approach, only buying stuff I get really good deals on. So far I have a real nice turbo, 880cc injectors, chipped my P72, got a BOV, wastegate, got a Ostrich and have under 400 in it so far and just need an intercooler, manifold, intercooler piping and the metal for the downpipe. That will be under 300 or around 600 depending if I go eBay on the intercooler or not.
Old Nov 28, 2009 | 03:31 AM
alejo98cx's Avatar
Its not that easy for me because I live in canada, ***** more expensive up here, im broke and a student so pretty much broke, I think this is good for me. And I dont think I would be able to find any ball berring turbo for so cheap. and alll i need is IC piping, BOV and a tune. My question was more like is this good for my civic, not to worried about hassel and saving a few hundred bucks on something that I dont think will work as well
Unless you guys really think I can get something better... tried looking on foroums found some dope ****.
Also, I dont really understand all the inner workings of a turbo like a.r rations and trims, what is shaft play? Like I understnad shaft between exhaust side and compressor side but what does it affect? How much is alot? How bad is it if there is a litte but of shaft play.... rebuild it or just run it A-Ok
Old Nov 28, 2009 | 07:24 AM
TheShodan's Avatar
Moderator
Yeah, I wouldn't do that deal. You still have to get all the water lines and appropriate fittings for that turbo, making your cheap find very expensive. I'd piece one together even w/ used parts from the Hondamarketplace before I do any craigslist ads. Yikes for that one.
Old Nov 28, 2009 | 10:33 AM
alejo98cx's Avatar
Word then I'll listen to the wise, thanks guys!
Only reason I have my doubts is because of things like this http://vancouver.en.craigslist.ca/rd...482887869.html just the turbo $400
also, can anyone answer my questions about ar and what not, I have read the stickies but am still not sure about it
Honda tech is the ****, by far the best foroum out there
Old Nov 28, 2009 | 12:39 PM
thumper64's Avatar
You can piece something together cheaper. A T28 is pretty small, and if it needs rebuilt, you're looking at a whole new CHRA. That's not cheap. An FMU isn't the best way to deal with engine management. Oil coolers are cheap on eBay.
Old Nov 28, 2009 | 03:25 PM
alejo98cx's Avatar
Would something like this http://vancouver.en.craigslist.ca/rd...481460941.html just bolt onto a normal Manifold?
stevenr2894
Apr 15, 2013 06:41 AM
sasinorm01
Mar 21, 2007 01:21 PM
Terrible One
Dec 21, 2006 04:45 PM
Guru Designs
Aug 19, 2005 10:28 AM
redteg
Jan 16, 2003 06:22 PM
