high flow cat--no O2 sensor hole
Old Nov 27, 2009 | 08:30 AM
kaka10's Avatar
Default high flow cat--no O2 sensor hole
hi just got a high flow cat kuz my oem was gutted but the one i received has no 02 sensor hole...is there anything i can do to put the sensor somewhere else or should i just send it back and hopefully get a replacement
Old Nov 27, 2009 | 10:34 AM
JP.MotorCity's Avatar
Default Re: high flow cat--no O2 sensor hole
make your own O2 bung, find a nut that fits the O2 sensor (not galvanized or zinc coated). Drill a hole in the cat, the same size as the threaded hole in the nut. Then weld the nut to the cat (slooooowwwly), thread in the sensor, plug it in, and DUN!
Old Nov 27, 2009 | 10:35 AM
gstrudler's Avatar
Or if you don't have your own welder, take it to an exhaust shop and they should be able to put one in for you.
Old Nov 27, 2009 | 05:54 PM
asianguy's Avatar
you could make your own hole for it
Old Nov 27, 2009 | 06:17 PM
HondaVerno's Avatar
you need an o2 sensor on it? i just looked at my pipe and there was none...maybe only on you 5th genners
Old Nov 27, 2009 | 09:04 PM
kaka10's Avatar
yea i need one...how much would they charge to put a hole on the cat?
Old Nov 28, 2009 | 04:41 AM
street_ride14's Avatar
you don't need a hole in your cat. get one pre-cat or post-cat, but not on the cat. You will not get accurate readings if you weld the o2 bung on your cat. Pre-cat is the best location.
Old Nov 29, 2009 | 09:45 PM
TheJGB3's Avatar
What are you talking about an OBDII cat has the post cat O2 sensor bung in the middle or at the end of the cat before it connects to the exhaust piping.
On my 2000 Civic EX it is in the center of the cat
On my 2000 Prelude type SH it is at the end of the cat just before the flange.
sorry no pic
To the OP- call the vendor that sold it to you and ask them if it is supposed to have a bung hole, and if it does then have them send you a new one. If it is not supposed to come with a bunghole then have the hole drilled where the bunghole is on your OEM cat.
JDM-Vic
Apr 29, 2010 05:04 PM
cubism
Welding / Fabrication
Dec 1, 2004 10:39 AM
Toda Party
Dec 26, 2001 11:47 AM
Etylorcen
Oct 25, 2001 07:31 AM
R134
Aug 27, 2001 02:08 PM
