Wheels won't turn!!! '90 B18A1 into '91 CRX SI
Old Sep 1, 2002 | 06:07 PM
pfcfutrell's Avatar
Default Wheels won't turn!!! '90 B18A1 into '91 CRX SI
We've dropped the B18 into the CRX but as we went to push it out of the garage we found the front wheels won't turn. The tranny and axles are good (shift linkage not in yet), i'm more than a little confused but it was getting dark by this time so we kinda gave up for the time being. Tomorrow we're going to check it out and see if it's something stupid we missed, anybody ever have a similar experience or have some idea of what we should look for??
Old Sep 1, 2002 | 06:30 PM
Blown90hatcH's Avatar
Default Re: Wheels won't turn!!! '90 B18A1 into '91 CRX SI (pfcfutrell)
Did you remove the metal spacer rings on the hubs and the dust ring on the axle? That will keep you from being able to turn the wheels once they are tightened down. Also, is it in gear?
[Modified by Blown90hatcH, 8:28 AM 9/2/2002]
Old Sep 1, 2002 | 11:02 PM
IN VTEC's Avatar
If the steering wheel turns without effort and does not have any return-to-center tendency, then how about checking to see if the steering tie rods are connected to the knuckles?
If there is resistance, then there is blockage somewhere. Find the hinderance and remove it. Shouldn't be anything real hardcore. At worst the axles could be the cause.
Old Sep 2, 2002 | 07:06 AM
Trey's Avatar
25 Year Member
Default Re: Wheels won't turn!!! '90 B18A1 into '91 CRX SI (IN VTEC)
Did you put the key in the ignition?
Old Sep 2, 2002 | 09:30 AM
slowerthanu's Avatar
New User
Default Re: Wheels won't turn!!! '90 B18A1 into '91 CRX SI (Blown90hatcH)
What are you talking about?
Old Sep 2, 2002 | 09:33 AM
Jaker's Avatar
Default Re: Wheels won't turn!!! '90 B18A1 into '91 CRX SI (Trey)
He means the wheels won't rotate, not "they won't steer".
Old Sep 2, 2002 | 12:30 PM
paulzy's Avatar
Default Re: Wheels won't turn!!! '90 B18A1 into '91 CRX SI (Jaker)
maybe in gear? maybe your brakes locked up also
Old Sep 2, 2002 | 08:54 PM
Default Re: Wheels won't turn!!! '90 B18A1 into '91 CRX SI (slowerthanu)
Depending on what axles you run, there is a metal spacer that is in the hub of the EF and there is a dust ring on the end of the axle....if these are on when you tighten the wheel on to the hub...the wheel will hardly move.
[Modified by Blown90hatcH, 9:35 PM 9/3/2002]
Old Sep 3, 2002 | 07:40 PM
4dohs4mohoes's Avatar
dude you said you dont have your shuft linkage hooked up...right?. well how about hooking it up and ptting it in NUETRAL.
Veruka88
May 13, 2013 12:48 PM
si 2
Oct 11, 2008 04:38 PM
bboixtc
Jun 27, 2007 02:37 PM
efrex
Jan 19, 2006 09:35 AM
One Bad GeeSeeR
Nov 10, 2002 12:12 PM
