Getting rid of rust in bolt holes
Old Nov 26, 2009 | 02:27 PM
berb_15's Avatar
Default Getting rid of rust in bolt holes
I'm about to start sanding/painting my engine bay but there's rust inside of a lot of my bolt holes... I don't want to paint without getting rid of it and can't really fit a wire brush in there, just wondering what people do to clean them out before paint? Thanks
Old Nov 26, 2009 | 02:53 PM
bar'dh22's Avatar
Default Re: Getting rid of rust in bolt holes
sandblast it
Old Nov 26, 2009 | 04:37 PM
berb_15's Avatar
Unfortunately I don't have access to a sandblaster...
Old Nov 26, 2009 | 05:12 PM
bar'dh22's Avatar
then your ****ed
Old Nov 26, 2009 | 05:20 PM
b18cKoupe's Avatar
or you could run a tap through it with cutting oil.
Old Nov 26, 2009 | 05:50 PM
bar'dh22's Avatar
this would help
Old Nov 27, 2009 | 03:17 AM
joycesamuel's Avatar
New User
Rust is very common in screw and nuts...The thing you need is sandpaper through which you can remove rust and then put the oil continuously everyday so that the rust may not come back...
Old Nov 27, 2009 | 03:45 PM
berb_15's Avatar
sounds good, I had thought of running the bolts back in with oil but the tap makes more sense, not sure why I didn't think of that.... thanks for the input
Old Nov 28, 2009 | 04:34 PM
FearTheH's Avatar
Yeah use oil just make sure you get all of it off otherwise there's no point in removing the rust. I'd say f*ck it and leave, it will come back right after you paint it regardless. Really more trouble than its worth. Just my trained opinion.
Old Nov 28, 2009 | 05:18 PM
berb_15's Avatar
What's this rust destroyer you speak of?? Is that the stuff that's supposed to convert rust into a paintable surface? I already bought some rustoleum primer so I'm good to go there.
Old Nov 28, 2009 | 05:21 PM
FearTheH's Avatar
Either way if you retap it, the paint surface will be cut and will eventually start rusting again. Not tryin to argue with you tho lol maybe I'm just misunderstanding your technique, if so PM me and tell me your exact process and I may just start using that one. Word!
Old Nov 30, 2009 | 09:57 AM
Psychoteen101's Avatar
To keep the rust from coming back, put some anti-sieze on the threads of the bolt before you install it.
Old Nov 30, 2009 | 11:22 AM
Transpoquick's Avatar
why do you want to paint a bolt hole?.
put anti-seize on the bolt like^^^ mentioned.
LOL.
Old Nov 30, 2009 | 01:18 PM
berb_15's Avatar
Thanks!
LOL.
I'm painting my entire engine bay. Plus my car was stolen and stripped so I'm just going to leave a lot of stuff out of the engine bay such as a/c and other miscellaneous stuff. Instead of letting it all rust out, I"ll be painting it. Instead of welding then or leaving a bunch of bolts in the bay paint's the best thing for it.
Old Nov 30, 2009 | 02:26 PM
bakertime's Avatar
Sandblasters are CHEAP. Like $25 cheap...then you just need the abrasive, a respirator and a compressor and you're set.
Old Nov 30, 2009 | 03:08 PM
FearTheH's Avatar
X2! Even if it breaks after a couple uses, its cheap so no big deal and as long as you accomplish what you're tryin to do then its money well spent. And to those who keep saying paint the holes then retap them, ill pay money to see you paint a bolt hole and retap it and not have rust come back, you've obviously never done any real body work, or just have no common sense what so ever.
Old Nov 30, 2009 | 03:21 PM
prelude1897's Avatar
Originally Posted by bar'dh22
sandblast it
now I know you have a bigger pic of your avatar
Old Nov 30, 2009 | 03:28 PM
Thanks!
OHHH, I see, you did not mention that.
Anyway, I would suggest just tapping, or "chasing" the threads.
Using a sandblaster will definetly remove the rust BUT, it makes a huge mess, I'll say it again it makes a huge mess. Thats a problem because when you go to re-paint no matter how hard you try you are gonna get sand in your paint, and trust me it does not look to hot.
If you are gonna blast use a "recycler" type blaster, it has a rubber nozzle on the end that you push against the surface or over the bolt hole and it collects the media and stores it in a bag where it gets sucked up again, much cleaner.
Hope my reply helped you.
rash
Apr 1, 2010 09:11 PM
Lee_eg6si
Paint and Body
Aug 31, 2008 02:12 PM
slowassciv33
Paint and Body
Aug 17, 2007 03:56 PM
enil01
Oct 4, 2006 02:16 AM
typhoon
Sep 20, 2004 09:17 AM
