fuel problem??
Old Nov 26, 2009 | 12:09 PM
TRIGA's Avatar
Default fuel problem??
so i have a 93 civic dx d15b7 with headers and intake.
it has an idle problem i searched and found the FITV and IACV threads. I cleaned them etc. The car still idles loopy.
My hose from the fuel tank that goes to the rail is cracked. i always get a nice smell of gas when i drive the car hard and come to a stop light. If i drive the car hard and then stop the rpms bounce 1k to 1.5k. Now if i drive normal it rarely happens. and it always idles btween 1k-1.5k when its cold.
ive cleaned the TB IACV FITV throttle cable.
i have a feeling my problem is fuel related. What is a common factor for idle problems with fuel. should i check the fpr? replace filter? please any help i tohught i could have solved this problem today but i can't
Old Nov 26, 2009 | 02:03 PM
TRIGA's Avatar
Default Re: fuel problem??
need an answer lets go
Old Nov 26, 2009 | 04:23 PM
TRIGA's Avatar
le bump
Old Nov 26, 2009 | 04:33 PM
l337h4l's Avatar
fix the cracked fuel line?
Old Nov 26, 2009 | 04:52 PM
TRIGA's Avatar
i did
Old Nov 26, 2009 | 05:25 PM
l337h4l's Avatar
check the vacuum hose for the FPR idle issues are mostly vacuum lines. double check them all. You can try the can of carb cleaner trick spray it around and if your idle changes you have found your vacuum leak.
I would say if that does not change tune up plugs, air filter, and fuel filter. Cap, rotor spark plug wires I don't see being a idle issue but you never know.
Old Nov 26, 2009 | 05:32 PM
TRIGA's Avatar
oem honda plugs wires and cap replaced. cleaned the fitv iacv and tb replaced the line from the tank to fpr
Old Nov 27, 2009 | 12:21 AM
TRIGA's Avatar
up
Old Nov 27, 2009 | 09:36 AM
TRIGA's Avatar
also the white piece that screws into the bore has a hole in it
Old Nov 27, 2009 | 07:39 PM
TRIGA's Avatar
bumppp
Old Nov 27, 2009 | 11:32 PM
nelson.jones07's Avatar
New User
I already have tried this but still I m finding the same problem Please provide some good suggestion.
Old Nov 28, 2009 | 01:27 PM
TRIGA's Avatar
i sprayed cleaner all around the IM TB and hoses and nothing no change in fluctuation
Old Nov 28, 2009 | 02:44 PM
TRIGA's Avatar
ok i just came back inside i checked my iacv again and cleand it again there are two holes and only one screen are they supposed to have two screens could this be the problem
Old Dec 2, 2009 | 05:49 PM
TRIGA's Avatar
bump
kona_4door
Sep 14, 2010 05:11 AM
pacificrim
Feb 15, 2009 08:56 AM
ben1284
Feb 18, 2008 06:17 PM
1989CivicSi
Jun 4, 2006 08:12 PM
girlie
Mar 6, 2003 09:58 AM
