helpp da wont start
Old Nov 26, 2009 | 10:31 AM
jdmk20z1h22who's Avatar
Icon3 helpp da wont start
IGHT SO I REPLACED THE FUEL PUMP THINKIN THAT WAS THE PROB AND MY DA STILL WONT START WHAT COULD IT BE IT CRANKS NICE BUT DOESN'T START WHAT COULD IT BE HELP PLZ
Old Nov 26, 2009 | 09:12 PM
ILS_09's Avatar
Default Re: helpp da wont start
Check battery. If it has the proper volts, looked into fuses. If your car cranks, check distributor. If not, look into the starter.
Old Nov 26, 2009 | 10:07 PM
541DB1's Avatar
Sounds like a main relay, that's the first thing I would check.
Old Nov 28, 2009 | 07:14 AM
thanks guys ima try that tommro if not any other ideas would be greatly apprecited
Old Nov 28, 2009 | 12:57 PM
nwstreets's Avatar
try the ecu or the ecu fuse too
Old Nov 29, 2009 | 07:48 PM
DOUBTS.72's Avatar
look in to the Starter solenoid might be messed up or just old starter, get an exchange rebuild starter for 50$ .maybe less. got mine for 46$.
Old Nov 29, 2009 | 07:52 PM
541DB1's Avatar
Sounds like it cranks just fine, just no start.
Old Nov 29, 2009 | 07:59 PM
DOUBTS.72's Avatar
how about the Fuel relay?looked in to that?
Old Nov 30, 2009 | 07:40 AM
541DB1's Avatar
Yeah that's what I suggested in the 3rd post, I read somewhere that Honda says yore supposed to replace that thing every 8 years??!! haha mine lasted 19!
Old Nov 30, 2009 | 08:47 PM
DOUBTS.72's Avatar
Ya. I noticed, just thought that I needed to state it again since he didn't mention replacing or checking it. haha man! 19 years, I say another Good thing about Honda oem parts! lol
Old Nov 30, 2009 | 08:53 PM
Moi Zver' (GSR)'s Avatar
i had the same problem and main relay was the issue, also make sure ur battery is good.
Old Dec 1, 2009 | 08:44 AM
RedMenDC2's Avatar
either your battery...or your altenator...or your starter...DA's has a problem on that. now that's one of the biggest issue for the 2nd gen DA's!
Old Dec 5, 2009 | 02:27 PM
yayy i fixed it thanks for the support guys it turned out there was no power going to my injectors
Old Dec 5, 2009 | 10:12 PM
DOUBTS.72's Avatar
Glad it got Fixed ..... Ps. just found out why my Da wont turn on, my Fuel pump is gone :/ fixing it till next week .
Old Dec 7, 2009 | 09:02 AM
Steven.'s Avatar
Starter, distributor? Try hitting the starter with a hammer, try popping the clutch if its a manual then you can eliminate things, does it have a CEL? Check the error code.
Old Dec 7, 2009 | 08:46 PM
DOUBTS.72's Avatar
I've checked and done every thing possible ...here is what i replaced ..Starter,Sparks,Spark cables,oil,oil F.,valve gasket(do to leak into Spark plugs ),checked the Dizzy working , Checked the relay for the Famous 3 clicks Working as well,replaced TPS,...then took my rear seat off.. turned the switch.. didn't here the fuel pump making any noise or spinning .. then removed the hose that goes to the fuel rail and turned the witch and no gas been pumped into my fuel rail and injectors ... so im like 99% sure is the Pump(might be wrong). I'll still take any suggestions :D thanx for trying and help ...oh almost forgot no Cel codes ! for some reason i get my Oil and battery light (battery is low but always crank it with jumper cables so it can have 12v) on ???? I just did a Complete tune up!, if you(general) have any idea of what could be causing this, i will appreciate it a lot :D??? thanx
Old Dec 8, 2009 | 05:52 AM
Steven.'s Avatar
Doubts.72 my guess is that its your fuel pump then as you are saying or perhaps it is your ecu? Process of elimination.
Old Dec 8, 2009 | 05:50 PM
DOUBTS.72's Avatar
ya Thanx a lot for trying and help Steven: . I'll update you on the weekend when i put in the new pump (Sunday).
Old Dec 15, 2009 | 08:06 PM
yea i ran a power wire to the injectors and the car turned right on
Old Dec 15, 2009 | 08:17 PM
DOUBTS.72's Avatar
Great!!!!!!what a relive right? haha ! man today i thought about why my car wouldn't start, and remembered that when I i replaced the injectors alot of gas leaked ...and my friend txt me telling me if i had fixed, told him to lets go buy gas, went got two gallons...put them in my DA and second crank! started right up! haha! man i felt happy as F***! lol:D now just need a valve Adjustment ...and smog checked !...
Tunerguy1989
Nov 16, 2009 03:52 PM
91greenbeast
19
Sep 30, 2008 09:09 AM
JDM_d15b_eg8
Oct 11, 2007 03:55 PM
IntegraPir4te
Mar 19, 2007 10:51 AM
PUSHER
Jun 21, 2004 11:21 AM
