help!!! type r issues
Ok I have a 97 ITR (JDM). The problem with it is that whenever I turn the steering to the right an move off I hear a clunkin sound an also a rubbing sound. U feel it a little in the steering wheel an right at the pedal. When u turn th steering to d left u only hear a rubbing sound. This happens at very low speeds with the steering turned but as u go faster it jus goes away. Things I have changed so far are axles gearbox ,lower control arms, upper control arms, lower ball joint, rack an pinion , wheel bearing, rack end, tie rod end, suspension, clutch, pressure plate, gearbox
He may be referring to the houseing on the inside of the bumper. If you look in your wheel-well, toward the front where your bumper is you'll find a big piece of plastic attached to the bumper going all the way down, then you'll see why it may be called a splash shield.
jdm_junkie8o8
Jan 20, 2010 02:41 PM
