help!!! type r issues
Old Nov 25, 2009 | 07:19 PM
Hondistic's Avatar
New User
Default help!!! type r issues
Ok I have a 97 ITR (JDM). The problem with it is that whenever I turn the steering to the right an move off I hear a clunkin sound an also a rubbing sound. U feel it a little in the steering wheel an right at the pedal. When u turn th steering to d left u only hear a rubbing sound. This happens at very low speeds with the steering turned but as u go faster it jus goes away. Things I have changed so far are axles gearbox ,lower control arms, upper control arms, lower ball joint, rack an pinion , wheel bearing, rack end, tie rod end, suspension, clutch, pressure plate, gearbox
Old Nov 25, 2009 | 07:26 PM
PaulMc's Avatar
Painfully Stupid
Default Re: help!!! type r issues
I'd check to see if the axles are in all the way, or, one may be rubbing on the strut.
Old Nov 26, 2009 | 05:54 AM
Hondistic's Avatar
New User
My axles are fine. No indication of rubbing. What else can I check
Old Nov 26, 2009 | 08:00 AM
Demon R's Avatar
check the splash shield it may be rubbing on it
Old Nov 26, 2009 | 08:04 AM
Hondistic's Avatar
New User
What's the splash shield?
Old Nov 26, 2009 | 11:42 AM
PaulMc's Avatar
Painfully Stupid
He may be referring to the houseing on the inside of the bumper. If you look in your wheel-well, toward the front where your bumper is you'll find a big piece of plastic attached to the bumper going all the way down, then you'll see why it may be called a splash shield.
Old Dec 5, 2009 | 12:38 PM
Hondistic's Avatar
New User
I did those checks and everything seems to be fine. What I notice is that wen I am turning an I hear d noise an I press on the clutch pedal it goes away
tag0617
Aug 23, 2010 10:33 AM
FreshCD5
May 14, 2010 01:17 PM
jdm_junkie8o8
Jan 20, 2010 02:41 PM
Audi RS4
Sep 25, 2003 07:16 PM
shortyz
Mar 29, 2003 03:36 PM
