gsr idle prob
Old Nov 25, 2009 | 11:13 AM
hardeeboy's Avatar
Icon6 gsr idle prob
i have a 94 coupe with a 95 gsr swap and everthing was fine but all of a sudden since it has cooled off a lillte were i leave it has been idleing funny like when i crank it it idles to 2500 and then when it warms up pretty good it idles from like 1500 to 2500 for alil while then it stops after it is warmed up all the way but that is very aggervating . thanks for the comments
Old Nov 25, 2009 | 11:32 AM
hardeeboy's Avatar
Default Re: gsr idle prob
anyone anyone out there
Old Nov 25, 2009 | 11:33 AM
Simkin314's Avatar
Fast idle thermo valve, FIT (bottom of throttle body)
function: allows more air into the intake manifold via a thermowax plastic insert thereby compensating for colder climates (and cold starts).
Recommendation: Depending on you global position/typical environment...open the end plate and tighten the white insert, thereby allowing less air through.
Old Nov 25, 2009 | 11:59 AM
hardeeboy's Avatar
alright thanks
cityjack
Jan 1, 2015 09:59 PM
Fnix
May 11, 2012 09:39 AM
Maxcapacity
Jun 10, 2008 06:11 PM
lsxtreme81
Apr 20, 2007 05:39 PM
94lsvtecdelsol
Oct 15, 2003 09:23 PM
