D15b Cam Timing
Old Nov 25, 2009 | 10:08 AM
KeithsDAteg's Avatar
Default D15b Cam Timing
Engine: JDM D15b Vtec
Question:
If cam timing is off by 1 tooth, would I be able to set the Igniton timing w/ a timing light to 16 Degrees?
Old Nov 25, 2009 | 11:16 AM
delsolproblems's Avatar
Default Re: D15b Cam Timing
And have it run well? No.
Old Nov 25, 2009 | 12:11 PM
So you are saying that, the distributor would be able to adjust far enough to get the pointer on the red line on the crank pulley?
I guess that is my real question. I understand that if cam timing is off that it's a bad thing, and would need to be corrected. Im just wondering if checking igniton timing is a good way to confirm cam timing.
Thank to all!
-Keith
Old Nov 25, 2009 | 12:12 PM
Old Nov 25, 2009 | 02:21 PM
Oh, I see what you mean. If you properly set the ignition timing and then replaced the timing belt a tooth off, you'd be able to see a noticeable difference in when the spark is occurring. You could at least partially compensate for this by adjusting the ignition timing but your valves would still be opening and closing at the wrong times, causing the motor to run poorly if at all.
Old Nov 26, 2009 | 04:43 AM
Well, I put a timing light on it yesterday. With the distributor fully advanced the best we could do was a hair past 0 degrees.
Would this mean the Cam timing probably needs to be reset?
Thanks again.
-Keith
Old Nov 26, 2009 | 05:43 AM
LTCxD2B's Avatar
i think i have this same problem with my d15b so the answers are appreciated
Old Nov 26, 2009 | 05:49 AM
Are you having hesitation/lowend power problems?
Old Nov 26, 2009 | 07:03 AM
LTCxD2B's Avatar
kinda and i cant move my distributor at all without the car boggin out and its slammed to the right
Old Nov 26, 2009 | 02:00 PM
Come on TECH....
Old Nov 27, 2009 | 02:50 PM
Make sure you're setting the timing properly. For OBD1, the little blue connector next to the ECU needs to be jumped and the timing gun pickup must be on the #1 plug wire. If you have that right and your cap & rotor are in good condition then you should really inspect the timing belt. Your problems can be caused by incorrect valve timing but there's only one way to know for sure.
Old Nov 27, 2009 | 03:46 PM
Well, im pretty sure cam timing must be the culprit. We gonna take the valve cover loose and the top belt cover off and check it out. Might have to break the tensioner loose and move the camgear back one tooth.
Anymore advice is greatly appreciated.
Happy Holidays!
-Keith
Old Nov 29, 2009 | 05:32 PM
For the record, It was the cam timing... Off one tooth. We took the top cover off and busted the tensioner loose, pulled the belt off, and turned the cam gear back one tooth.
Man those timing marks on the cam gear are sketchy, and a little hard to read.
Runs great now!
johnwohl
Apr 1, 2008 07:29 PM
G2_Fella
Nov 8, 2006 10:50 AM
stevescivic
Sep 6, 2006 10:02 PM
donnjuan2point2
Mar 11, 2004 10:49 AM
