B16a?
Ok so I just picked up an ej1 with a b16a. I need to do an oil change but don't know what oil filter to get. If I went to pepboys what kind of filter should I ask for? Also what's the best oil to use and how man quarts?
its best to use 5w-30 viscosity, and i personally use royal purple full synthetic blend(race track proven)
B16A oil sump capacity is 4.2 quarts with an oil and filter change according to the manuals. I've found it usually takes about 4-1/4 to 4-1/3.
All '86 and newer Honda automotive 4-cylinder engines (except F20C and F22C) spec the same oil filter.
Purolator Pure One filters have good recommendations. I generally stay away from Fram filters due to their low quality innards.
if he has a b16a (jdm) than the filter numbers you guys have suggested are all wrong! i am in the middle of my first b16a oil change and am having problems. the usdm filter is the same as any us civic but jdm is different. i have 4 civics and my stock of filters are not fitting. i cross referenced the filter that was on it but the stp part no. isnt fitting either! this sucks!
just got a stp s2903 to fit. cross reference if you dont like stp. i stopped using fram after i had a gasket bust open! this is only for the B16a, not b16a1, 2, etc!
Factory all the way!!!!!! I only run honda filters on royal purple. No fram junk.
The usdm honda oil filter will fit on the b16a no prob i have a jdm b16a i picked up in jan an i removed the jdm filter an screwed on the us filter no prob. Whats the prob with your filter???? To big? to small? not threading on?????
so your saying i magically made a different filter fit!?! jeez i hate forums!
You can hate forums all you want, but it still doesn't change the facts.
So you run the 15400-PLM-A02? Just wondering, because it's manufactured by Honeywell/Fram with cheaper quality internal components than the Filtech-made 15400-PLM-A01 . . . not that it really matters that much.
wix is good(aka napa) get the gold line though, dont play around with silver. bosch has filters at autozone now, but i havent looked up any test results yet. fram are ok for a daily driver.......... my 93 si has seen nothing but fram filters(except the original) and castrol gtx 5w-30. swtched to high mileage at about 100k......runs like a champ, no engine issues at all. but its usually hard to beat the oem filter. for a daily driver with some abuse once in a while, i see absolutely no need to run synthetic. its a waste of money imo unless you beat on it pretty hard.
i have the same exact swap in my 96 civic my d16y7 took the same oil filter as my JDM b16a fram tough guard ph3593a
I also run Fram filters and I like them. My favorite one though is the Napa Nascar Select, it seems to have the best particle filter rate for the $. Becuase it has like a 98.9 or 99.5% MP Efficiency and yet it only costs like $3.12.
I believe Targa250R just said that the Honda Filter is made by fram.
