lsvtec piston q
i have a standard bore b18a and was thinking of using some different pistons for my vtec head swap. what pistons will work without having to bore my block? will b18c or b16a pistons with a standard bore fit? thanks
All B series pistons are interchangeable except for the B20. JDM CTR pistons will give you the highest comp., but piston to valve clearance is really close especially when doing an lsvtec set up.
Here's a site for you... http://www.angelfire.com/dc/lsvtec/lsvtec.html
yup, i'm using the pr3's in my setup, its about 11.2:1/11.3:1 or something, check out; http://www.bojangs.com/calculator/ hth
hoffmanb16
30
Oct 30, 2017 03:41 AM
TurboSiCoupe
Feb 21, 2003 07:51 AM
