Should I remove my A/C
Old Nov 24, 2009 | 05:53 PM
nextproject97's Avatar
Default Should I remove my A/C
I have a jrsc gsr hatch and am looking for input from you guys. Should I pull my A/C ? I don't daily drive the car and its only hot here 4 mos a year tops . When I do drive it in the summer 90 % of the time I dont even use the A/C due to horsepower loss with it on I dont wanna get pulled on lol . I do however like my A/C when I am just cruising on a day off going to the mall or something.What do you guys think keep it or remove it ?? I cant make up my mind so tell me what ya think ! whats the horsepower difference gonna be 5 hp , 10hp ??
Old Nov 24, 2009 | 07:35 PM
civiconfire's Avatar
Default Re: Should I remove my A/C
when your WOT your compressor turns off anyways. so there really is no loss. i say keep it..
Old Nov 24, 2009 | 07:58 PM
RaceCarRyne's Avatar
less weight.....
Old Nov 24, 2009 | 08:29 PM
KWayRacing's Avatar
Dude keep your air. Can't be cool if you are sweaty. Literally. AC is so nice. I kept AC on my dd GSR-t car. Was hell during install and any repair, but so very worth it. I say to all who shelve AC for HP in their DD......why?
Old Nov 25, 2009 | 05:09 AM
kyden's Avatar
theres no hp loss when the ac is off. the clutch disengages and the pulley freewheels.
Old Nov 25, 2009 | 05:51 AM
fcm's Avatar
fcm
Old Fart
Absolutely, keep the A/C, as mentioned there is no HP loss when A/C is not on and very little when it is on.
There are ways to offset the "extra" weight of the A/C system that are a lot more comfortable then pulling the A/C system. 94
Old Nov 25, 2009 | 06:26 AM
miguel329's Avatar
keep it. i took mine out becuase of the turbo if not id still have it
Old Nov 25, 2009 | 06:52 AM
l337h4l's Avatar
Only remove it if it does not function. Its about 50 pounds of weight if you remove the entire system. Not worth it in my opinion especially if it still works.
Old Nov 25, 2009 | 07:20 AM
its a honda... not a bmw...
Old Nov 25, 2009 | 08:22 AM
kyden's Avatar
what is that supposed to mean?
Old Nov 25, 2009 | 10:33 AM
take it out....
Old Nov 26, 2009 | 08:00 AM
LTCxD2B's Avatar
i want to keep my a/c as well too because of window fog and leather seats but with the turbo comin its not looking good without major issues and if the car is all motor keep it its not a track car
Old Nov 27, 2009 | 07:40 PM
The engine is a supercharged gsr I was thinking of pulling the A/C to install another half size radiator to use for a heat exchanger for my lht intercooler .I want to be able to keep those intake temps as cool as possible . I dont know so far the heat exchanger I have seems to work fine and yeah I do like A/C on occasion .The A/C works great and the compressor , dryer and expansion valve are new this past summer .Sounds like for now I'll keep it I guess thanks for all the input .Oh and as far as the weight well I am fully loaded last race weight including me was 2780lbs in an EK hatch thats heavy. I have system, subs, full int , ect ... car runs pretty good but it is heavy for a hatch .So as far as losing the A/C for the weight thats not gonna happen if I would see considerable gains in hp say 5-10 then it would be worth it if not the A/C stays
Old Nov 28, 2009 | 07:36 AM
CivicSi95's Avatar
i dont believe you are going to pick up 5-10 hp by removing. maybe 1-3 hp gain. weight savings is the only advantage and not having a sweaty back far outweighs weight savings in my opinion. you can buy an oem aluminum a/c mount which will save you 5 lbs. i dont even daily drive my car but i kept the a/c because its very necessary in oklahoma in the summertime. i had a friend pass out in starbucks one day because of heat exhaustion after he was driving his hatch with no a/c. thats how hot it gets here
Old Nov 28, 2009 | 10:30 AM
what was he driving with the windows up or just not going over 5mph with the windows down?
Old Nov 28, 2009 | 01:56 PM
HCivExoo's Avatar
i am sorry for your freind but that is pretty funny. I can laugh i don't run a/c in my DD. anyone can say whatever they want. the extra heat caused by a/c in the engine bay compared to a larger heat exchanger probably in a better position to allow more overall cooling.
How much boost you running? If you are running more than 10lbs it could be possible to gain 5-10 hp on a hot day. I know the modified JRSC really start to build heat and heat sink into the intake air.
zeroz
Sep 1, 2005 06:53 PM
Kashi
Apr 12, 2005 11:17 AM
brega3
Jul 23, 2003 03:09 PM
FourthGenHatch
Jul 13, 2002 06:56 PM
Rhetoric
Oct 6, 2001 01:54 PM
