Buying a lip was a bad idea
Old Nov 24, 2009 | 10:35 AM
czirr321's Avatar
Default Buying a lip was a bad idea
I lowered my car and just got a brand new paint job, and I installed a type-r lip the other day and now my front end is about an inch and a half off the ground and I scrape ALL the time, it's frustrating, but now I am screwed because from the scarping it scratched my newly painted bumper! Like the part on the top of the lip when I scraped the lip moved and scratched the bumper, so if I take the lip off there will be scratches. It is a ABS plastic lip, does the polyurthane or whatever ones scratch your bumper?
Old Nov 24, 2009 | 11:16 AM
Autointeg's Avatar
Default Re: Buying a lip was a bad idea
oem looks way better plus it doesn't add an extra 2 inch drop to ur car :D
Old Nov 24, 2009 | 11:19 AM
czirr321's Avatar
Is OEM plastic or polyurthane? I just want it not to scratch my bumper, because it wont be cheap to get repainted.
Old Nov 24, 2009 | 11:30 AM
FearTheH's Avatar
Raise the car up some.
Old Nov 24, 2009 | 11:55 AM
czirr321's Avatar
Then it will be ugly! I love the way it sits now, my tires are tucked, and it looks sexy.
Old Nov 24, 2009 | 11:57 AM
trustdestruction's Avatar
The OEM lip is plastic, but IMO looks best unpainted. Even though it's plastic, it's pretty durable. I've scraped it hard quite a few times, with nothing worse happening other than the obvious scratches on it. I used to have a "mugen" lip. The OEM lip scrapes way less.
Old Nov 24, 2009 | 12:16 PM
FearTheH's Avatar
Lol, I don't know your history with cars, but if you've never owned a lowered car it definitely takes a different driving style. Speed bumps are your enemy! And definitely pick up an OEM lip, my em1 lip is still holding strong although a couple of tabs are broke, I've got them rigged with hot glue and its holding very well. Its been through some **** too, you should definitely check into one
Old Nov 24, 2009 | 01:29 PM
czirr321's Avatar
Here is the front, I brightened the front with photoshop so you could see how close the lip is to the ground.
Old Nov 24, 2009 | 03:01 PM
g230sport's Avatar
that looks sick. id get an em1 lip for your car and call it a day.
i just put a stock lip on my car, and i love it
Old Nov 24, 2009 | 04:08 PM
TunerN00b's Avatar
That's what happens when you don't use double sided tape across the entire bumper where the lip sits on it. If you had, the tape would have taken the abuse, and your bumper wouldn't be scratched. Some people even go so far as to use stick on weather stripping between the edge of the lip and the bumper (rubber makes a good protector).
Oh well. Hopefully, lesson learned. Get the bumper repaired, attach the lip correctly, and get used to scraping it, since you want to try and drive a dumped car.
Old Nov 24, 2009 | 05:01 PM
burningrex's Avatar
should have got an oem lip
Old Nov 24, 2009 | 05:10 PM
steveo135's Avatar
yea i was going to say the same thing about the weather stripping...
doesnt matter what the lip is made of, if you use weather stripping scratching is not a porblem
Old Nov 24, 2009 | 05:20 PM
Enables's Avatar
I like sitting low but its not even worth it anymore roads today, i lower as low as possible but leave room i got the same setup and i always scrapped got it repainted 5 times.
Old Nov 24, 2009 | 06:14 PM
r33dm0n3y's Avatar
my only question is why when you got your car painted you didn't have your front bumper holes shaved where your liscense plate used to be? one of the silliest things i think i see on hondas is relocated plates when you got 2 big holes in your bumper.
Old Nov 24, 2009 | 06:20 PM
czirr321's Avatar
The reason I got the relocator is because I did a front end conversion and the holes are too big, and I cant screw my plate on, I got a parking ticket for having no front plate, so the relocator was my only option, I perfer no front plate.
Old Nov 24, 2009 | 06:37 PM
98civdx's Avatar
Master Detailer
it should have 2 gold plates that are threaded and behind those holes, then you will be able to mount your plate.
Old Nov 24, 2009 | 09:59 PM
boxeocampeon's Avatar
i would raise the car a little bit
Old Nov 24, 2009 | 11:01 PM
obuhmyuh's Avatar
bondo works wonders
Old Nov 24, 2009 | 11:46 PM
es01civy's Avatar
Just wait when a rabbit runs out into the middle of the road at night..... A.V. sucks!! haha
Old Nov 25, 2009 | 04:33 AM
Autointeg's Avatar
lol, damn tucked huh? with cali laws i wouldn't bother going lower than 22. too attractive like the color though.. :D
Aj Gulvas
Honda S2000
16
May 30, 2016 12:45 PM
GR_DC2
Feb 8, 2012 12:11 PM
Zerophase
Paint and Body
Aug 18, 2008 06:45 PM
ejONE.mike
13
Sep 24, 2005 08:13 PM
xstalkrx
Apr 19, 2003 12:27 AM
