what ECU - JDM B18C with mods
Old Nov 24, 2009 | 08:03 AM
mikeivb's Avatar
Default what ECU - JDM B18C with mods
What ECU would you all recommend running with my current setup:
97 jdm b18c
s80 tranny with lsd
ctr cams
skunk2 throttle body
skunk2 intake manifold
blox velocity stack
blox air cleaner
benen fuel rail
b&m fuel pressure reg
b&m fuel gauge
dc sports 4-1 header
Mugen twin loop catback with magnaflow high flow cat
This is what I'm currently running:
P06 with obd1 conversion harness, chipped with chrome.
Problem is its not running that well, idles kind of rough and fuel pressure is low (around 37)
Old Nov 24, 2009 | 08:20 AM
Gunmetal_B20_Hatch's Avatar
Default Re: what ECU - JDM B18C with mods
fuel pressure is a bit low, but should be OK... I'd check for a tune-up and/or retune.
Old Nov 24, 2009 | 08:25 AM
YANG_JDM's Avatar
Are you just running on a base map tune?
Old Nov 24, 2009 | 08:53 AM
mikeivb's Avatar
do u know how I can check?
Old Nov 24, 2009 | 08:56 AM
mikeivb's Avatar
I know I need a retune, but I want to spent as little as possible right now just to get it running smoothly to get me through the next few months...
Old Nov 24, 2009 | 08:59 AM
rick_rabies's Avatar
I'm not Rick!
go to www.pgmfi.org. and download crome for free on your cpu and look at the basemap for that motor. and it you have the stuff plug a cpu into your ecu and pull the map and compare.
use that allen head on the top of the FPR and turn it up
Old Nov 24, 2009 | 09:12 AM
mikeivb's Avatar
what kind of plug would I need?
Old Nov 24, 2009 | 09:28 AM
I'm not Rick!
are you using chips
or are you using an emulator like the ostrich 2.0v?
if its a chip then...you would need alot more.
but let it idle and adjust the fuel pressure a tad bit. how does it run when your on the gas?
Old Nov 24, 2009 | 09:43 AM
mikeivb's Avatar
are you using chips
unforunately i think its a chip... i'm new to this so am not that knowledgeable... i'm waiting for dry weather and a friend of a friend who has all the software, chip burner,etc to help tune, but in the meantime I was hoping for a quick fix, to get it running smoothly, as it doesnt look like the weather in vancouver is goign to dry out anytime soon
i know someone who is selling a stock ITR P73 ecu for pretty cheap, i'm wondering if that would smooth things out temporarily..
when i'm on the gas its not too bad, not as bad as when idling.. but i dont want to push it too much without a good tune
Old Nov 24, 2009 | 09:47 AM
I'm not Rick!
do you have a wideband?
it should be kinda rich when cold 10-13
warm at idle 14.7
when cruising 13-15
in boost realy jamming on it it should be under 12.5.
if i was you id get a stock ecu asap just to have. and leave it stock. i always keep a stock ecu for backup
Old Nov 24, 2009 | 09:55 AM
mikeivb's Avatar
warm at idle 14.7
when cruising 13-15
I dont have a wideband, but i was thinking of getting one in early spring to help with tuning.
for 97 JDM B18C, P72 OBD2?
Old Nov 24, 2009 | 10:01 AM
I'm not Rick!
itr ecu would prolly work better (as in stock)
but there is a guy on that can make you a chip for $30 according to your mods.
itl prolly run better but it wouldnt be dead on the spot.
check it out.
http://www.xenocron.com/
Old Nov 24, 2009 | 02:17 PM
mikeivb's Avatar
check it out.
thanks for the advice... do you think a stock gsr ecu will be ok to run with the mods i have?
Old Nov 24, 2009 | 02:23 PM
93egSLEEPER's Avatar
it will handle them ok, but to get the most out of them and to keep the car running correctly tune it.
Old Nov 24, 2009 | 04:13 PM
thumper64's Avatar
what about datalogging? Wouldn't you be able to get what you need to tell if you're running ok that way? You can solder in a 4 pin header, jump a connection and use a phone data cable to read the data if you download an application from the internet. If you get the cable off eBay, it will be like $3.
I haven't tested it, but for $3, it's worth trying.
Old Nov 24, 2009 | 04:18 PM
Hybrid96EK's Avatar
A stock ANYTHING is not going to be "ok" for you to run.. Come on. You dramatically increased the air/fuel flow characteristics of this engine and now you have questions if you can cheap out for the time being and get away with a stock ECU? Negative. You need to get some money together and tune it. If you can't tune it either park it or return it to stock so your stock ECU will suffice and call it a day. I still to this day don't understand why people spend all this money on mods only to cheap out in the end on the most important item of all.
Old Nov 24, 2009 | 04:54 PM
mikeivb's Avatar
I am planning on getting it tuned, but not for a few more weeks or so...i have a friend of a friend who can do it, just not sure how soon... for the time being i'm not driving it as much, but unfortunately its the only car i have.
Old Nov 24, 2009 | 07:25 PM
thumper64's Avatar
You'll need a wide band O2 to tune it, and it wouldn't be bad to have it after that. Scrounge up the money and install that, then up the fuel pressure to be within what Rick Rabies posted. It's not the right way to tune, but it's a little better.
Hondas run notoriously rich, so you may be able to get away with how you are now. The wide band O2 is the only way to tell if you are or not though. I don't think the JDM B18C had a knock sensor, so it won't retard the timing if you're getting detonation.
Old Nov 25, 2009 | 10:18 AM
mikeivb's Avatar
Well i'm hoping to get an AEM FIC with Wideband and have i tuned before I push it early next year.
in the meantime I have a friend of a friend who's going to help me burn a better chip, hopefully the rain will stop
Old Nov 25, 2009 | 10:20 AM
I'm not Rick!
yeah after a chip, you wont have much fun in the rain. i dont even bother bringn it out in the rain. 1st and 2nd with turbo just spin like a ****.
Old Nov 27, 2009 | 03:56 AM
Koopa Troopa's Avatar
This is what I don't understand... You have an adjustable fuel pressure regulator, your idle is rough and your fuel pressure is low...
My question is why haven't you adjusted your adjustable fuel pressure regulator? You do realize your rough idle is more than likely caused by your fuel pressure or lack of, right?
You could get that motor running pretty decent with a stock ECU just by playing with fuel pressure and advancing your timing via the distributor. You haven't really done anything significant to that engine. Keep it simple, use a stock ECU and a VAFC, use a wideband to tune it and be done.
Old Nov 27, 2009 | 07:00 AM
Hybrid96EK's Avatar
Adjustable fuel pressure regulators and VAFC's are complete garbage. Do things right or don't do them at all.
Advancing the distributor will change the whole map. high cam and low cam. Not the smart thing to do especially if you don't even know if the engine wants more timing. Come on. Advance the timing with your stock ECU so the car starts picking up knock with the knock sensor and pulls twice what you put in. Sounds real smart, no?
All these tuning experts chiming in about the 'low' fuel pressure.. Does anyone have a manual where they can verify what the fuel pressure SHOULD be? Of course not. Everyone just assumes its 'low'. The manual for the 98-01 GSR specifies 47psi *WITH THE VAC LINE OFF* which would be ~37psi with the line on. Imagine that! So you still think just cranking the fuel pressure up, which BTW stresses the fuel pump, and tossing some timing in there is going to solve the problem?
Old Nov 27, 2009 | 07:25 AM
mikeivb's Avatar
me and a friend are going to be checking out the fuel-pressure next weekend, when I get the P72 ECU that I ordered... I'm going to try to purchase myself a wideband soon..
Old Nov 27, 2009 | 08:38 AM
Hybrid96EK's Avatar
The ECU has nothing to do with fuel pressure...
Old Nov 27, 2009 | 08:49 AM
Bennyboy1717's Avatar
JDM p73!!!
