98 civic turns over but doesnt start
i was driving then there was no power lights turned on it cranks over but dont fire up i heard it can be the distributer can somebody please help
if you are sure its ignition related then start troubleshooting.
http://techauto.awardspace.com/ignition.html
make sure you are getting fuel...are the plugs wet with gasoline?
A motor needs 3 things to run. Air/fuel/spark. Make sure you are getting fuel, then check the spark. If one of those 2 things are not there then that is the issue. Let us know what tests you have done and we'll go from there.
thanks for the fast replies guys trying to get a friend to take me there now took the cap off and there was a green wire hanging there the cap was clean too
