My low beam headlight dont work on my EG...
Can someone help me out on my low beam headlights on my EG? My high beam works but everytime I switch with low beam, it doesn't work, plus my radio and my clock keeps resetting everytime I turn on the ignition. I checked all my fuse and they are all good. Im thinking maybe it is the fuse box??? I need to make sure it is the fusebox before I replace it. Any help???
well i had a problem with my eg awhile ago check the wires that connect to the light buld they might be lose or touching something that might cause them 2 make ur car reset its self oh and i know u said that you check the fuses inside the car i say get a tester and check them good cuz when this happend 2 my car i check them and they were good u know wat mean right cuz u might of just look at them and saw they werent burn but sometimes they look alright and they dont work ,,,,,so look in to that before u change it and if everything is good just change the fuse box .../. good luck
jimboek
Apr 30, 2007 05:22 AM
R1_Owner
17
Sep 28, 2006 11:29 PM
DJNauTicz
16
May 13, 2005 07:49 AM
