foglights in eg stopped working... in car now... help me!
Hey guys... I am out in my yard with my laptop in the pass. seat so I can access the forum for help.
I have a 93 si with factory fogs... recently reinstalled a new alarm, and now the factory fogs aren't working.
I am checking all connectors under the dash, and all looks good... so now I am thinking FUSES...
BUT... what fuse would be the one for the factory fogs??
This might be a really stupid question, but I am running on 1.5 hours of sleep, and I can't think straight.
I am literally in the car working now... so any FAST help would be much appreciated.... I can even pm my cell if someone wants to talk me through this.
Re: foglights in eg stopped working... in car now... help me! (R1_Owner)
Follow the wires from the fuse box and see if you can find the relay or fuse.
I would think it ties into the factory headlight wiring also, do they work? If not, check the headlight fuses in the fuse box.
there should be a relay switch some where under the hood for the lights, as well as a fuse. also check the the connections behind the light, maybe water damage, or corroded wires. doen't hurt to check the switch as well, a faulty switch will cause this.
i have provided a link on the bottom. it's more for installation, but it's straight from the dealer and should show you where everything should be sitting.
http://www.hondaautomotivepart....html
this is for the 2/3door civic.
also did you install the alarm or had someone do it? maybe they unplugged something and forgot to replug it.
Re: foglights in eg stopped working... in car now... help me! (philosofy1)
they both were working fine, and then both stopped... if it was corroded wires, wouldn't it have been an foreseeable *did I spell that right?* issue??
The headlights, signals, brake lights, and interior lights are all working fine... not a single problem. Just suddenly fog lights no workie.
I am trying to follow all wires and traces them to a fuse... somewhere.
KINDA tight being upide down in my seat with my head under the dash. HAHA!
it does sound like a realy/fuse problem, but you want to cross out all the possibilites. click on the link i sent you, it should help to loocate the relays and fuses.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by R1_Owner »</TD></TR><TR><TD CLASS="quote">I ******* GIVE UP!!!!!
relax, one who masters patients, masters life.
oh... wait... think I found a fried fuse... it looks like the jumper fuse in the diagram... damn thing is almost melted. Bet that can't be working anymore.
Guess I am off to pep boys for a 15a... maybe that will work.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by R1_Owner »</TD></TR><TR><TD CLASS="quote">oh... wait... think I found a fried fuse... it looks like the jumper fuse in the diagram... damn thing is almost melted. Bet that can't be working anymore.
before you replace it, double check for shorts, or you're just going to be working twice.
with a voltage meter.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philosofy1 »</TD></TR><TR><TD CLASS="quote">
with a voltage meter.</TD></TR></TABLE>
Thanks...
... I'll post again when I get back with the results of my finding...
Thanks...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philosofy1 »</TD></TR><TR><TD CLASS="quote">relax, one who masters patients, masters life. </TD></TR></TABLE>
I am doomed then.....
Re: foglights in eg stopped working... in car now... help me! (HondaJack)
and I think you meant... one who masters patience *as in the trait* vs patients *as in people seeking medical or psychological help*.
However, I think the ***-clown that did my alarm either clipped something or misran a wire. I changed every fuse, checked all connections, etc.
It is just not going to happen tonight.
Thanks for everyone's help.
This is worse case scenario but you could just pull out the wirirng and start over.
I did this with a set of depo fog (OEM looking) lights. There was a brass "C" clip that held all the wires together at one point in the harness. That damn "C" clip over time frayed all the wires. I had sooooo many fog light headaches I finally said *** it and pulled all the wiring, and then made a harenss myself.
Its not that hard, hell, even vatozone sells a fog light wiriing kit seperately if you want to go that route. I just soldered all my own **** together. NEVER had a problem again.
my friend got a EG hatch....and he just order some jdm fog light from passwordjdm.com and its not fitting right....how much do he have to cut off to make it fit?
Re: (snsamotors)
click on the link above ^^^ it's directions on how to install it, it should show you.
with the oem foglights no matter where you buy them in the wiring harness for the fogs it comes with a relay and a fuse check both.
also there are two grounds one inside the car and one outside closer to the lights them selfs.
also if the foglights are not fitting properly you need to angle the lens properly so the covers will fit on. and if thats not working then apperently somthing in the bumper was not cut right
Dropspeed
04-21-2011 05:34 AM
-Championship-
Audio / Security / Video
11
09-18-2006 01:18 PM
deetz84
16
05-30-2005 06:49 PM
GSlowR
12
10-05-2002 07:14 PM
