Radiator question
Old Nov 23, 2009 | 12:48 PM
S_K_C's Avatar
Default Radiator question
I own an eg and my plastic radiator recently broke so i replaced it with an aluminum one. its been about 2 weeks and the coolant in the reservoir is already gone. just wondering if this sounds right.
sorry nood question =(
Old Nov 23, 2009 | 01:33 PM
Former User's Avatar
Default Re: Radiator question
You shouldn't lose coolant that quickly. Check for leaks. Did you bleed the cooling system? Did you replace the radiator cap?
Old Nov 23, 2009 | 02:53 PM
92lxsleeper's Avatar
what do you mean it broke?
mine failed due to the headgasket failing between cylinder 2 and 3 and allowing too much pressure in the cooling system, thus blowing the plastic tanks off the rad.
i think you might have a blown headgasket.
Old Nov 23, 2009 | 11:28 PM
S_K_C's Avatar
well there was a crack in the plastic. i dont see any leaks and i did bleed it out and the new radiator came with a new cap. sorry to b noob but how would i know if my head gasket was failing.trying to learn as much as i can thats why im on this site
Old Nov 24, 2009 | 12:02 AM
ke98248's Avatar
compression test is an easy way. if you have near 0 - 30 psi reading on any cylinder the gasket has failed at that area at the very least
Old Dec 7, 2009 | 10:46 AM
strategy400's Avatar
You can get a test kit at napa etc. to check for exhaust gasses in coolant. It's like $50 but you can reuse it on any car. You stick it in the radiator neck and if the blue fluid changes to yellow you have blown headgasket or a crack in block/head.
vtec2017
Mar 18, 2017 04:24 PM
maddcrx
Honda S2000
Jun 7, 2008 10:03 PM
civicsir94
May 20, 2008 03:21 AM
B17AGSR
Jun 8, 2004 07:23 AM
CRXSIR1
Jan 12, 2003 05:53 PM
