h22 compression test an leak down test need help
Old Nov 23, 2009 | 10:32 AM
93sibubble's Avatar
Default h22 compression test an leak down test need help
been havin problems wit my jdm h22 did a compression test an hav 200 200 an 180 180 on 3 n 4 cylinders also did a leak down test on cly 1 gt 95 cy2 gt 85 cy 3 gt 85 an cy 4 85 alsoi hav a valve tap in the head an all i did was change my auto 2 manual tensioner an 440 injectors its spuders an sounds lik **** need help
Old Nov 23, 2009 | 02:35 PM
93sibubble's Avatar
Default Re: h22 compression test an leak down test need help
can any1 help me oout
Old Nov 23, 2009 | 03:15 PM
93ex4door's Avatar
your compression is good man leak down seems fine.Could be uve advanced to much on ur timing and with the bigger injectors causing ur tap and spuder.
Old Nov 25, 2009 | 04:23 PM
93sibubble's Avatar
my cam gears are set to 0 so cant be advanced or retard
Old Nov 25, 2009 | 04:39 PM
Linh.'s Avatar
check your valve lash?
Old Nov 26, 2009 | 02:12 PM
toofast4u752's Avatar
why 440 injectors???? remap the ecu? if you just threw em in there, thats why... your running rich as hell....
Old Nov 28, 2009 | 10:34 AM
RaceCarRyne's Avatar
x2 on the injectors. and as far as the taping goes. either your valve lash is too much, tentioner is not tight enough, broken valve spring.
Old Dec 1, 2009 | 08:39 PM
93sibubble's Avatar
ive checked the valve lash seemed way 2 tight loosen them up an runnin 440 cuz nitrous
Old Dec 11, 2009 | 01:44 AM
unless your spraying nitrous at all 100% of the time, your injectors are making you run rich, the rest of the time.... thatll be the biggest reason for your car to bog out and spudder... those injectors without some form of tunning will dump about twice the amount of fuel as the stock ones... so... either set up the ecu, injectors, nitrous correctly.... or just deal with running rich... i guess its better than the retards running a DRY kit, then asking why their motor blew?!?!??
oh and the "2 tight valve lash" will not cause tapping.... only if they was loose! think about it?!?!
Old Dec 13, 2009 | 08:48 PM
Darrell Bs 10SecEG's Avatar
If that dont work,Put back in the stock injectors and see if it gets better and if it does,Then that was your problem.But if you want to keep the injectors in,Get a Hondata or chip with a street tune for those injectors and use a adjustable fuel pressure regualtor when you tune the car.
Old Dec 19, 2009 | 07:09 PM
93sibubble's Avatar
i did all that ecu was remaped n hav no clue changed my timing belt cuz it stretched was old
92TypeR
Engine Management and Tuning
Mar 12, 2010 11:23 AM
redline7
Nov 7, 2008 07:49 AM
JFG Kevin
Jul 19, 2006 07:49 PM
fastcrxva
Aug 5, 2005 05:05 AM
Declectic
Feb 2, 2005 09:03 PM
