Is there a reason, why people do not use Skunk2 stage 3 camshafts very often?
Old Nov 23, 2009 | 08:00 AM
KangBanger's Avatar
Default Is there a reason, why people do not use Skunk2 stage 3 camshafts very often?
It is more expensive than stage 2 but not by that much. It is not suitable for street? I found a good deal for sk2st3, and i wanted some advise on them.
my motor is b18c1 with Itr pistons overbore 81.25 with sk2 pro series intake mani. If i am doing a camshaft swap i am planning on upgrading the valve spring and retainer as well.
Old Nov 23, 2009 | 09:18 AM
morgan@synapse motorsport's Avatar
Default Re: Is there a reason, why people do not use Skunk2 stage 3 camshafts very often?
pro-series are the choice now because they offer a wider powerband
Old Nov 23, 2009 | 11:28 AM
KangBanger's Avatar
If i was on a budget and i found a good deal on sk2st3, is it worth it to get it?
Old Nov 23, 2009 | 11:53 AM
00Red_SiR's Avatar
All Motor Mentor
I wouldn't. I have rarely seen anyone make much more if any power with those cams over the S2S2's cams. I would stick with the older tuner stage 2's or go to the pro series cams. There's a reason why those old stage 3's "are such a good deal".
Old Nov 23, 2009 | 11:59 AM
K7-1Ktrevor's Avatar
Loved
Community Favorite
I made 224whp sae on s2s3's.
they have a weird dip in the powerband though right after vtec.
Old Nov 23, 2009 | 12:00 PM
00Red_SiR's Avatar
All Motor Mentor
What was your build?
Old Nov 23, 2009 | 12:10 PM
killerpenguin21's Avatar
the stage 3's are like an almost stock low cam with a rediculous high cam.
kids used to run them so they had the mad crazy vtecs yo!
it makes for crappy power application IMHO. the pro1's are much closer low vs high cam and you can barely tell there is a crossover which is how it should be.
Old Nov 23, 2009 | 02:44 PM
mar778c's Avatar
Community Builder
Community Influencer
Cmon guys, S2S3 are an excellent cam but it definitely requires the right combination of parts and motor. A stock 1.6 or 1.8L is going have a crappy powerband with those cams.
Old Nov 23, 2009 | 04:19 PM
im nt knocking the cam, you just need to have a setup that is on the high cam forever to make power imho.
of course ive never run them personally but ive driven a car that has...it was pretty crappy, then all of a sudden you had a ton of power for like 3k rpm's and then you had to shift.
Old Nov 23, 2009 | 11:58 PM
Loved
Community Favorite
2.0l, 12 to 1 comp, ported head, hytech rep header and full 2.5" ebay exhaust. rrev's to 8700. motor makes good bottom end power, but vtec is def where it really comes on. traction is more of an issue then having low end...
Old Nov 24, 2009 | 04:09 PM
2001B18C1GS-R's Avatar
but morgan told me that pro series cam eat your rockers after 10k or so....
p.s morgan is the owner or synapse
VtecKiDD
31
Jul 22, 2011 01:46 PM
Liquidgsr
Apr 9, 2007 10:44 AM
vitalik
Sep 12, 2006 06:02 PM
elemska20
May 23, 2006 12:33 PM
ramz7887
11
Jun 2, 2003 06:57 AM
