b20 swap..pcv issues
On a 1997 b20 motor being swapped into a 1994 dc2.. does this pcv look correct? I'm using a stock LS manifold and I ran into some idle issues after firing the motor up for the first time... the car is reading no CEL.. the rpm keeps jumping up from 1500-2500 rpm. Any clue ?
PCV is routed correctly if the other hose is attached to the intake.
Have you checked for vacuum leaks? If not that sometimes the seat in the fast idle valve have been known to come loose causing a high idle.
My brother made a mistake that had the same symptoms as you're having.
He had the IACV plug and the purge solenoid plug mixed up. The idle was going up and down just like your explaining.
Maybe?
Your hookup of the PCV is correct.
Maybe?
EJ1A1
Jan 6, 2017 12:07 PM
Scott Little
Nov 12, 2015 01:06 PM
skerrttt
Apr 26, 2013 07:19 PM
