Idle issue...
Old Nov 22, 2009 | 04:08 AM
jkalex05's Avatar
Default Idle issue...
I have a b16a2 swapped into a 96 EK coupe....
Anyways I really didn't have any problems till I switched to a chipped ecu.
Now when my car is cold my idle hops from 1500rpm to about 2k. It happens intermidently and only on idle.
Also I notice that if I leave my car idling and it warms up it stops and idles at 900-1krpm.
Any idea what could be causing this? Is it the ECU? or is it another problem?
Old Nov 22, 2009 | 08:45 AM
acake em1's Avatar
Colonel Cake Mix
Default Re: Idle issue...
sounds like an iacv
Old Nov 22, 2009 | 12:30 PM
jkalex05's Avatar
Originally Posted by acake em1
sounds like an iacv
Well I just installed my skunk2 intake manifold about a month ago and I cleaned out the iacv and didn't have any issues till the day i put it in the new ecu.
Old Nov 22, 2009 | 12:40 PM
acake em1's Avatar
Colonel Cake Mix
did u install your ecu and clean out your iacv at the same time?
Old Nov 22, 2009 | 12:44 PM
jkalex05's Avatar
No like I said I put on the new ecu about two days ago and cleaned the IACV last month.
Old Nov 22, 2009 | 12:48 PM
acake em1's Avatar
Colonel Cake Mix
no cel i assume?
Old Nov 22, 2009 | 01:47 PM
jkalex05's Avatar
no cel i assume?
nope....
Old Nov 22, 2009 | 02:28 PM
acake em1's Avatar
Colonel Cake Mix
what ecu are u running?
HCivExoo's Avatar
what kind of chip? if it is programable ecu you need to turn the duty cycle of your IACV down
Old Nov 22, 2009 | 09:20 PM
jkalex05's Avatar
It is a chipped ECU from monotech.
Old Nov 22, 2009 | 10:12 PM
acake em1's Avatar
Colonel Cake Mix
do u know what ecu it is though...
Old Nov 23, 2009 | 02:24 AM
HCivExoo's Avatar
Monotech? never heard of them .... i would try and talk to who ever tuned the chip for you.
Old Nov 23, 2009 | 12:49 PM
lmsem1's Avatar
happened to my car, clean the iacv, then check wiring, then ecu... may be one or a combo of all of them.... or maybe whoever tuned it messed up... and does it ever sputter when youre driving at all???
mikeunreal2
21
Apr 13, 2006 06:36 PM
BeerBaron105
Jun 7, 2005 02:22 AM
danslerugueux
18
May 15, 2004 01:12 PM
saucyhatch
10
Nov 13, 2003 08:25 PM
