How do you guys think my turbo set-up will run??
Old Nov 21, 2009 | 07:44 PM
93grayeg's Avatar
Default How do you guys think my turbo set-up will run??
Hey guy's I got a 89 si hatch w/a b20b , 46,000 on the motor , im using a ls tranny with a act clutch, car has pwr full-race radiator, and full-race traction bar set up. . . motor is all stock internally . . I have the whole kit pretty much pieced together. . Everything is new. .
Basic no name cast turbo manifold
t3/t4 no name turbo
tial 38mm wastegate w/ 8 pound spring
tial blow off
no name ebay front mount
go-autoworks charge piping kit
will be running open downpipe for a little while
car is obd1 converted and will be tuned at innovative motorworks in pa
dsm 450's
The car will be tuned on 8 pounds and never anymore than that, the motor is all stock and very healthy. . it will be daily driven but not hard at all . . How do you guys think it will run ?? what kind of power should I expect?
Thanks
( here is a pic of the car )
Old Nov 21, 2009 | 08:02 PM
Glock17's Avatar
Default Re: How do you guys think my turbo set-up will run??
Your set-up should run fine, you should pick up a walbro pump and AFPR to your list of mod. Nice and clean car by the way.
Old Nov 21, 2009 | 08:04 PM
93grayeg's Avatar
thanks man , sorry forgot to mention the walbro pump , I have a 255 walbro as well
Old Nov 21, 2009 | 08:37 PM
4drdohc's Avatar
i would never run no name brand parts. thats just me
Old Nov 21, 2009 | 08:44 PM
93grayeg's Avatar
ok guys I should of known this was gunna happen, I dont care what you guys think of no name parts, first of all its a low boost set up , im using an oil restrictor, its hard to mess up a cast manifold , and a intercooler . im not using a cheap wastegate, as for the turbo i have never had any issues with them , So lets keep this about how my set up is gunna perform, I dont care what you think of the parts im using
Old Nov 21, 2009 | 09:48 PM
EFPhilly's Avatar
You should def upgrade to arp head studs...just my .02
Old Nov 21, 2009 | 10:31 PM
TheShodan's Avatar
Moderator
I think that what this person is correlating is that suspect parts could hinder the already speculative aspect of how your engine will perform. I don't think they meant that they were judging you as an enthusiast.
I hate to say this, but YOU asked.... Someone answered.
Old Nov 22, 2009 | 06:51 AM
92redhatch's Avatar
You'll make around 200whp
Old Nov 22, 2009 | 07:03 AM
azandford's Avatar
^x2
Old Nov 22, 2009 | 07:08 AM
EARLdaSQUIRREL's Avatar
official honda whore
if the setup is installed properly with no leaks and no other problems it should make 200+ but that has nothing to do with the reliability or how long it will last
atleast your not cheaping out on the tune like everything else
Old Nov 22, 2009 | 07:24 AM
thefraz's Avatar
I had a similar setup b20b that made 277 at 12psi and 255tq, with a miniram and 60-1,the new owner dynod 367 on 20psi. its been driven hard for a year and still no problems, On 9 psi which is a little closer to your max psi, it made 235ish i believe
Old Nov 22, 2009 | 08:40 AM
93grayeg's Avatar
no im not going cheap on the tune at all . I was thinking some where around 200
Old Nov 22, 2009 | 08:41 AM
93grayeg's Avatar
thats really good numbers , my motor is all stock though. . I think 8 pounds will be safe with a good tune
Old Nov 22, 2009 | 09:03 AM
EFPhilly's Avatar
It's all about the duty cycle of those injectors, some motors on the dyno max 1000cc's out at around 16 pounds, just as long as your injectors are at a ample duty cycle and not close to maxing them out then that is a safe tune. Also if you have a boost controller you can get it tuned for a certain slightly higher psi (with the controller slightly turned up) then turn down the boost controller to whatever psi you wanna run. Im going to tune my LS to 14 pounds, then turn down to 8 (7.5 psi is stock wastegate setting for my turbonectics wastegate), 7-9 is a nice medium for winter driving too.
Old Nov 22, 2009 | 04:33 PM
93grayeg's Avatar
true
Old Nov 28, 2009 | 12:13 PM
thefraz's Avatar
my b20 was bone stock off the pallet not even head studs, it was a super budget build due to some crazy bad luck i had had in the past with expensive builds and fault oil pressure senders, and oil pump failure, i took it cheap, made good power, the car still runs amazing
96teggylsse
Jul 6, 2012 12:36 PM
ZakkWylde
Honda Civic (2001 - 2005)
19
Jun 7, 2007 08:59 PM
thelate1
Jan 27, 2005 03:08 PM
projectpat817
Feb 5, 2004 05:17 PM
CalvitoSol
Jul 9, 2002 02:45 PM
