E-Brake locked up on rear passenger side!
So I pulled my E-Brake up a little too hard, and my right passenger brake is totally locked. Usually when I let the E-Brake down, it makes a "click" sound, when the brakes release. This time when I let it down it didn't make the click sound. Also when I pull up on the E-Brake, it is a lot easier to pull up than usual; until about halfway up, when it gets really hard to pull. My E-Brake has been stuck like this before, but when it gets stuck I can pump the brake and it will release. Not this time. I took up the carpet and center console to see if the cable was sliding in and out of the housing properly, and it is. Please help!
had same problem with my 00 integra gsr abs!!! i had to replace the whole caliper and while i was at it put all new brake pads ETC! and rebleed the lines! its not hard and well worth it!
bleeding 98-01 integras are
f1 f2
r4 r3
sequence! goodluck
f1 f2
r4 r3
sequence! goodluck
