hey guys what da motor oil fiter number for jdmb20b
Old Nov 20, 2009 | 09:48 AM
allmotorjdmb20b's Avatar
Default hey guys what da motor oil fiter number for jdmb20b
?? srry for the dumb question and what filter do u guys use. im asking because mine has a cheap one on it.
Old Nov 20, 2009 | 11:34 AM
ek-g6's Avatar
Default Re: hey guys what da motor oil fiter number for jdmb20b
I used honda, hamp or mobil one, but thats just me.
Old Nov 20, 2009 | 12:18 PM
dayvid05's Avatar
I stick to the cheap Fram oil filter (PH3593A). There isn't anything wrong with them, especially if you're changing your oil every 2500 - 3000 miles anyway.
Old Nov 20, 2009 | 12:40 PM
Spawne32's Avatar
purolator pure one, best filter for the best price, stay away from fram filters, they are absolute junk.
Old Nov 20, 2009 | 06:36 PM
Honda_ThuGZ's Avatar
knN
Old Nov 20, 2009 | 06:37 PM
josh-roy's Avatar
Can't go wrong with Honda.
Old Nov 23, 2009 | 10:44 AM
post filter numbers thanks
Old Dec 9, 2009 | 11:35 AM
tttt
Old Dec 9, 2009 | 11:41 AM
akacoke's Avatar
x2
Old Feb 10, 2010 | 05:44 PM
its actually a dart b20 block so what are the filter numbers and thanks
Old Feb 11, 2010 | 05:35 AM
zedron's Avatar
All B series block can use the same oil filter. Either go with the Purolator or OEM Honda. If yo ugo to honda tell them you have a 96 CRV and need an oil filter. But I would go with the Purolator.
Old Feb 11, 2010 | 06:11 AM
.:Stirfry:.'s Avatar
Purolator is the best way to go. but yea all b series use the same filter
Old Feb 11, 2010 | 06:17 AM
backwoods's Avatar
Honda Oil Filter P/N - 15400-PLM-A02
Old Feb 11, 2010 | 08:45 AM
icucnme's Avatar
Can someone show me proof that the honda filter is the best? No you can't. Why don't you do some research instead of doing what h-t tells you. Multiple test have been done showing the oem honda filter is not as good as the purolator P1 or the mobil 1 and the k&n. Anyone know who makes the honda filter? It's actually made by Honeywell and that is a parent company of FRAM! Honda part # 15400-PLM-A02 Internally they are almost identical to the orange FRAM filter. Including the cardboard endcaps and fuzzy filter material. Hooray for oem bandwagon kids!
Use your own brain. Put the honda tech down
Old Feb 12, 2010 | 08:08 AM
Muskie Man's Avatar
Honeywell makes Hondas oil filters, the same company that makes Fram. I only use the OEM Honda filters but I bet the Frams are nowhere near as bad as everybody claims. As far as I know Honda uses only two different oil filters these days, one for the s2000 and one for everything else. I use the s2000 filter on my b18c5 as it is larger(the same size Honda used for Civics 15 years ago). The way I look at it, if I cannot afford OEM parts, I cannot afford to drive my Hondas.
Old Feb 12, 2010 | 08:12 AM
Spawne32's Avatar
http://www.knizefamily.net/minimopar...ers/index.html
Old Feb 12, 2010 | 08:38 AM
Muskie Man's Avatar
That page shows a cut up Fram PH8A filter. That is the filter my first car used, a '77 Ford Granada coupe w/302ci v8. Its says the filters are manufactured to meet original manufacture specs. It also says those filters were cut up back in '99. That is about the time that Honeywell began manufacturing the OEM Honda filters. A lot could have changed since then. Again I do not use Fram, but I do not believe they are as bad as many say. If I cannot afford to use OEM parts, I cannot afford to drive my Hondas.
Old Feb 12, 2010 | 08:54 AM
Spawne32's Avatar
im not gona argue with you, but if you want a good filter you stick with wix and purolator
Old Feb 12, 2010 | 09:11 AM
Muskie Man's Avatar
I also feel filters are not worth arguing over. But that page says Wix manufactures the Napa line of filters. 11-12 years ago all I heard is Napa Gold is the best there is. So I bought one for my Accord back in '99. Anytime my Accord sat for a few hours it would tick loudly with the Napa Gold filter when started. Seems that it had a bad anti-drainback valve and was draining all the oil back to the pan. That page that was linked specifically stated that is not possible with a Wix filter. In fact that is Wix's main marketing point. Thats when I started using only Honda oil filters. I used to order 10 at a time for only $39.50 from Manchester Honda. Thats only $3.95 each for OEM Honda. I am not sure what Manchester charges these days. King Motorsports also used to charge much less than the dealers for OEM Honda filters.
Old Feb 12, 2010 | 09:13 AM
TheAsian's Avatar
Yea this is gonna get ugly. Me personally I dont like fram, after what I have seen once in a shop from one.
Honda dose use Honeywell now same manufacturer as fram. But that dose not mean it is the same design or materials. I will say that.
Use a Purolator, wix, Napa gold filter, K&N, and Mobil 1 are good filters also but getting up their in price.
Old Feb 12, 2010 | 09:30 AM
Muskie Man's Avatar
Whats the reason to not use OEM Honda oil filters?
Old Feb 12, 2010 | 09:50 AM
Spawne32's Avatar
Theres no real reason not to use oem filters, its just that certain aftermarket filters are designed better then certain OEM brands. Purolator Pure one filters are the best design for the money imo.
Old Feb 12, 2010 | 10:13 AM
Muskie Man's Avatar
And they very well could be better than OEM Honda. But its what I'm unsure of in life that I'm most cautious about. I may be a little hard-headed but until something is proven to me I'll stick with OEM. $0-$3 more for the OEM filter is worth the piece-of-mind imo. Spoon Sports and also King Motorsports(the Mugen distributer and builder of my b18c5) both recommend the OEM filters.
Old Feb 12, 2010 | 10:14 AM
Spawne32's Avatar
thats your prerogative lol i get peace of mind knowing how well built purolator pure one filters are constructed
Old Feb 12, 2010 | 10:42 AM
thatdb8's Avatar
Y do some ppl use the s2k oil filter for the b20? They said it was better?? Ne 1 hread of this??
