having problems with clutch.
Old Nov 19, 2009 | 09:32 PM
WTFINEEDBBQ's Avatar
Default having problems with clutch.
well this has happened twice to me while driving my 94 hatch, the clutch would lose pressure and it wouldnt be enough to engage the gears. the first time it was cause i ran out of clutch fluid so i added more and bled it. the second time fluid was full but as i was driving i had clutched in and felt and heard a little pop and instantly lost pressure to my clutch but the pedal didnt drop to the floor i tried re-bleeding it but still didnt gain any pressure. im guessing it may be my slave cylinder or i need a new clutch. i never really had any problems puting my car into gear.
the car has 160,XXX miles dont know too much of the maintanence done from previous owner.
Old Nov 19, 2009 | 09:35 PM
Del Namco Solo's Avatar
Default Re: having problems with clutch.
check your master and slave cylinder. have someone sit in the car with it on, and pressing on the clutch, on and off, and look for leaks. my clutch leaked at the slave cylinder (right where it engages the clutch fork for the tranny) so I replaced it and I haven't been leaking since.
Old Nov 19, 2009 | 09:42 PM
hmm we did do that but didn't suspect any leaking anywhere but ill give it another try.
Old Nov 19, 2009 | 09:45 PM
whats the time frame on losing pressure? mine was a fast leak so it was obvious. if you have the money might as well do precautionary upgrades on the master and slave, but that's just me.
Old Nov 19, 2009 | 11:18 PM
mine was pretty quick but with no leaks but im thinking of replacing my slave if thats causing the problem. or just save up for a b series swap and change everything.
Old Nov 20, 2009 | 04:27 PM
Koopa Troopa's Avatar
Sometimes the seals in the master cylinder or slave are worn out just enough for the fluid to pass through without showing any signs of leaking.
In a closed hydraulic system, i.e. your clutch any signs of fluid loss means there is a leak. Have you checked the master or slave? Have they been rebuilt more than once?
Old Nov 21, 2009 | 04:03 PM
hmm that may explain.. so far i checked the slave im starting to think my slave needs to be replaced. im pretty sure it hasnt been rebuilt before.
Old Nov 22, 2009 | 02:59 AM
The general rule of thumb is; only rebuild once then replace. The cylinder will wear out and the seals won't fit right.
the171
Sep 14, 2017 04:36 PM
EddieLe76
Jan 14, 2010 01:50 PM
garyc17
Dec 18, 2006 10:24 AM
Nations Sickest CRX
Aug 30, 2005 03:53 PM
95excoupe
Dec 12, 2003 01:18 PM
