need some help with primer (pics inside)
When you sand primer, it's going to look different because of the composition. Especially when you lay it on wet and it flows over making a sealed/film over.
You don't have to spray more primer unless you're breaking through to the lower levels of metal or whatever.
The other alternative is to use a sealer, which is something like an epoxy primer, or a regular 2k urethane primer, reduced, sprayed on to the car wet like a basecoat to get it to be all the same color.
Hopefully that helps.
Try sanding part of the car and see if it does the same thing. Primer will change color from before sanding to after. Pretty much anything will change slightly when you sand it, it's just how it works. There's nothing wrong though, as long as it's looking the same everywhere (as opposed to only doing it in some spots, which would indicate a problem).
IROCKCIVICS
Paint and Body
Dec 8, 2007 11:01 AM
