Looking for 2 wire locations
I'm installing a remote starter this weekend, and I've got every wire mapped out except for two.
1) Defogger/Defroster: Is the wire for this in any of the harnesses near the fuse panel? Color?
2) Neutral Safety Switch: Same as above. Alternatively, is my only option to wire down to the switch itself?
Thank you
Thank you
Check the fuse box inside the vehicle, i believe that's the power source for the rear window defroster. Wiring harness should be located on the left side under the carpet and stuff, running along under the scuff panels and side of the rear seat to the rear window itself.
lsvtecej6
27
May 7, 2009 07:48 PM
mooze
Aug 12, 2006 10:10 AM
GSRaCeRbOI
Audio / Security / Video
Jun 17, 2002 07:31 PM
