95 Civic Built Head, wont start!
Old Nov 19, 2009 | 07:00 AM
95civicej1's Avatar
Default 95 Civic Built Head, wont start!
I got a 95 civic with a stock b16 bottom end, just put a stage 5 cnc post-n-polished head on it, and now the car wont start.
The car has fuel and spark, turns over, just wont start.
The head has a 5 angle valve job, major port-n-polish, etc. but is running stock b16 cams. Could that be my problem?
Old Nov 19, 2009 | 08:04 AM
dez6's Avatar
Default Re: 95 Civic Built Head, wont start!
double check your mechanical timing.
Old Nov 19, 2009 | 08:15 AM
95civicej1's Avatar
i have checked it twice.
ill check it again once more.
Old Nov 19, 2009 | 08:32 AM
dez6's Avatar
Do you have compression? Are all sensors plugged into the correct positions? Valves adjusted properly?
Old Nov 19, 2009 | 08:38 AM
95civicej1's Avatar
have not checked for compression yet, but i dont see how it could of lost compression with just swapping out a head.
all sensors are plugged up correctly.
and from what i can tell the valves are all adjusted properly.
Old Nov 19, 2009 | 12:08 PM
x-s-i-v's Avatar
ide say ur getting something wrong with ur cam belt. are u sure of ur makings and referance points
Old Nov 19, 2009 | 12:12 PM
Too_slow_eg's Avatar
How long has the head een sitting. I just did he same thing on a motor I built and it turned out to be stuck valves
Old Nov 19, 2009 | 03:27 PM
cjordan's Avatar
i would recommend checking timing and doing a compression test as already stated.
Old Nov 19, 2009 | 03:32 PM
EFPhilly's Avatar
get a feeler guage to check the valve lash, maybe you bumped them and turned the screw on accident. But a compression check would def be the first thing I would check since it cranks over, it will be a hell of a lot easier than checking valve lash.
S_F
34
Nov 22, 2012 10:54 AM
black_89gt
17
Apr 29, 2012 08:58 AM
TcUiRvBiOc
Feb 22, 2009 04:32 PM
evilk
Aug 9, 2004 06:39 PM
