F22B
Ok so im talking to this guy outta jdmenginescorp.com and the F22B motor does not have a knock sensor.....so i was wandering if i jus bought the p39 ecu if i would still have to install a knock sensor, he told me he didnt know? LMAO! if you work in a jdm motor place wouldnt you know that? LOL! Can anyone point me in the right direction.
Thanks!
Thanks!
Research is your friend:
http://www.cb7tuner.com/vbb/showthread.php?t=81303
http://www.tegger.com/hondafaq/f22b/index.html
The P39 does not need a knock sensor. Same with the PT3 and PT6 from USDM accords. P39 is over-priced and I can tell you from personal experience it won't make the motor run any better than the PT3 or 6, or the the stock P14 with a knock sensor installed on your F22b.
Lots of options here, but if you want the P39 get your checkbook out.
Ok, So If I Dont Need A Knock Sensor Then I Can Do The Swap And Not Have To Worry Bout Any Lights Coming On Bout A Knock Sensor Or anything In That Matter? I Read Alot Of Forums Bout People Needing Them Or Having Problems With A Knock Sensor....I Got Told When I Was Gunna Put A H23A1 in my car id have to install a knock sensor?......jus tryin to get the help I need.
Thanks For Everyones Help And Time!
If your worried about engine lights get a pt3 ecu from a usdm accord. They are 30-50 dollars compared to the 150+ for the p39 ecu, or knock sensor.
I drove my f22b on my p14 from the prelude for months with no troubles. The knock sensor went bad quickly, and I always had a light on. I put the pt3 in and the light went out, but the performance was the same.
Taking it further when I put a f22b ecu in the performance was the same.
In my opinion the pt3 is just perfect considering the price, and lack of knock sensor circuit.
I ran my F22B on the p14 ... just welded a bolt on the block and threaded the knock sensor in ... never had any problems with the knock sensor after that
motor blew from over reving tho haha ...
