alright uh i have no idea.
Old Aug 31, 2002 | 10:47 PM
HatchBox's Avatar
Skoobie no more...
Default alright uh i have no idea.
ok my interior lights wont light up at all...i replaced the switch like most of u said...but still nothing...what else can i check?
Old Sep 1, 2002 | 02:13 AM
Jayseal22's Avatar
Default Re: alright uh i have no idea. (xxkenyon419xx)
fuse
Old Sep 1, 2002 | 07:43 AM
Louie B.'s Avatar
I didn't see your original post, so I'm going to list the obvious:
If you have no light no matter where the switch is positioned:
Use a multimeter or testlight to test if you have voltage going up there. you either have a blown fuse (just because it LOOKS good doesn't mean it is, test it with a meter), burned out bulb, or your + wire has been cut or pinched off somewhere between the fusebox and the light itself.
If you have light with the switch in the "on" position, but not in the "door" position:
You either have bad door pins or a cut or pinched off wire somewhere between the door pins and the light itself.
If you have light with the switch in the "door" position, but not in the "on" position:
You didn't screw the light fixture up into the ceiling yet, did you? The light gets it's ground for the "on" position through the mounting screws.
[Modified by thumpu77, 8:45 AM 9/1/2002]
Old Sep 1, 2002 | 09:52 AM
Steve Berman's Avatar
Default Re: alright uh i have no idea. (thumpu77)
Do your rear lights work when you turn on your head lights? the interrior fuse and the rear taillight fuse are the same. May help you troubleshoot the problem.
Old Sep 1, 2002 | 12:11 PM
HatchBox's Avatar
Skoobie no more...
Default Re: alright uh i have no idea. (Steve Berman)
yeah tailights and the lisense plate bulb lights light up...here is my previous post https://honda-tech.com/zerothread?id=245494 thanks for the help
Old Sep 2, 2002 | 01:16 AM
Louie B.'s Avatar
Oh, that's right. I remember now... It's your dash lights that are troubling you, I was thinking dome light when you said "interior" above.
Did you check out the dimmer ****?
I'll assume that's what you mean by 'switch' above, test the wires that plug in to the dimmer **** to see if you get 12v to one of them when your headlights are on.
If not, it has to be either the fuse or the wire from the fuse to the dimmer switch.
[Modified by thumpu77, 2:22 AM 9/2/2002]
Old Sep 3, 2002 | 10:07 AM
HatchBox's Avatar
Skoobie no more...
alright so the dimmer switch is not getting any power at all...but the fuse is...so it must be what...i tried to follow the wire but it ducks behind everything and i cant follow it...what now
Old Sep 3, 2002 | 07:11 PM
Louie B.'s Avatar
Well, the easy way to fix it would be to just run a new wire from the parking light wire to the dimmer switch, put an in line fuse on the wire because you won't be going through the factory fuse anymore. I can meter my wires at work tommorow and tell you tomorow night which color wires to use.
Old Sep 4, 2002 | 05:17 PM
HatchBox's Avatar
Skoobie no more...
awesome thanks
Old Sep 4, 2002 | 11:03 PM
Louie B.'s Avatar
Ok, try this;
Run a jumper wire from the red w/ green wire on the dimmer switch to the heavier guage red w/ green wire comming from the headlight switch(this wire should show 12 volts when the parking lights are on.) put a 10 amp fuse on the wire to protect everything.
Old Sep 5, 2002 | 11:03 AM
HatchBox's Avatar
Skoobie no more...
and where can i find this head light switch wire...sorry i looked but there is alot of red wires...
Old Sep 5, 2002 | 02:59 PM
Ham'ed Hatch
Guest
Posts: n/a
ah i think you have a short in the wiring somewhere in the interior. just hack into (splice) the red/black (parking lights) wire and hook a switch up to it. voila. problem fixed.
Old Sep 5, 2002 | 03:03 PM
HatchBox's Avatar
Skoobie no more...
Default Re: alright uh i have no idea. (two.oh)
idk if u know the 90 civic std...but under the center console there is a plug of some sort...well there was...till i pulled it off accidently..anyways it has 4 wires going to it...2 red 1 black...and i think a white...its on the drivers side and it just folds undernetithe the center console...but when i put 2 together it lights up my dash and all the dash lights...but it wont turn on/off when i turn the lights on/off....anybody know what im talking about?
Old Sep 5, 2002 | 08:15 PM
Louie B.'s Avatar
I believe that would be your factory cigarette lighter plug, you could put a toggle switch between those 2 wires and make your lights work that way, but it's not really the right way. the parking light wire I'm refering to is under your steering column. it comes from the switch.
Old Sep 9, 2002 | 06:07 PM
type Gendy's Avatar
big ups to red hook
Old Sep 9, 2002 | 06:19 PM
HatchBox's Avatar
Skoobie no more...
Default Re: alright uh i have no idea. (shoddy116)
yeah joe what up?? u gotta post some pics of ur car man!
[Modified by xxkenyon419xx, 7:20 PM 9/9/2002]
bigbookben
Aug 7, 2018 02:26 PM
curtie94
Jun 5, 2011 09:28 AM
zsudz922
Sep 25, 2009 08:25 AM
kelliehager
Jan 14, 2006 07:23 PM
desync
Oct 5, 2002 02:19 PM
