which bearings to use, D16
hey everyone, well im building my y8 block. Im using FJ 75.5mm vitara pistons with forge rods but im confuse on one thing. Do i get .50mm ACL bearings or standard siz bearings?
standard bearings... oversized bearings are for rod/crank clearances that are too loose.
the oversized pistons only determine what cyl. bore you have to run and what size rings to get.
What determines the bearing size is the crank journal sizes and the block's journal sizes. If it has only been micropolished, you get standard bearings, then use plastigauge to check the clearances. If they fall w/in spec, you don't need the OEM "color-coded" bearings used to correct clearance issues. A more precise way is to use a micrometer & snap/bore gauge to measure the room for bearings.
FYI If you've cut a stock Honda crank more than .0009", it's already removed the hard coating, and isn't worth using.
boostedefhatch
May 13, 2010 11:02 AM
