How do you remove exhaust piping from a 94 Accord?
Old Nov 17, 2009 | 06:06 PM
Greatness's Avatar
Default How do you remove exhaust piping from a 94 Accord?
Im trying to replace the oil pan gasket but I have to remove the exhaust pipe blocking it. How do I remove the pipe? There's two bolts with a spring with some sort of locking nuts connecting it to the catalytic converter and when I used a ratchet or a wrench nothing.
Help would be much appreciated.
Old Nov 17, 2009 | 07:49 PM
fleetw00d's Avatar
Default Re: How do you remove exhaust piping from a 94 Accord?
Assuming it is similar to my 93's, it might be easier to disconnect the "A" pipe from the manifold and the bracket on the back of the block, leave it attached to the converter and just undo some of the rubber hangers to allow the pipe to drop far enough to remove the pan. The bolts/nuts at the converter are probably rusted pretty badly, better to leave them alone until/unless the pipe and/or converter need to be replaced.
Old Nov 18, 2009 | 02:44 AM
YeuEmMaiMai's Avatar
yeah what he said pull the pipe at the exhaust manifold pipe and just after the cat
Old Nov 18, 2009 | 04:54 AM
kccord's Avatar
That's what I did. Take the headers out, swing the downpipe to right side (facing forward) and take the middle frame. Had enough access to take out the pan. Tried to remove the bolts on the downpipe before cat but highly impossible, also sprayed some wd40 it didn't help. Wouldn't recommend it even if the car is supported by axle stands, watch yourself, these bolts are tight.
Old Nov 18, 2009 | 06:34 AM
Greatness's Avatar
Thanks thats what I thought.
Old Nov 18, 2009 | 06:36 AM
Greatness's Avatar
thanks everyone
Old Nov 18, 2009 | 07:45 AM
jhammond_82's Avatar
Reject Papi
i'm not trying to be ignorant, but if you can't figure out how to unbolt exhaust, are you sure you should be pulling the oil pan off yourself? like i said, i'm not trying to be a dick here. but if you can read a manual on how to change the gasket, i'm sure it would tell you how to take the exhaust off.
Old Nov 18, 2009 | 07:51 AM
Greatness's Avatar
The bolts are all rusted in. I used WD-40 and nothing. I removed the three nuts in the front trying to get the exhaust pipe off but theres some sort of locking bolt at the top locking the manifold to the exhaust pipe and I cant get that off to detach if from the exhaust manifold.
Old Nov 18, 2009 | 10:29 AM
Reject Papi
the bolts were rusted badly on my exhaust too. i installed a cat-back last week. instead of just taking the cat back off, i had to take the cat AND the cat-back off. i had to cut the stock bolts off, and use other bolts. if you have a grinder or sawzall, you might be able to do it a little easier. or, just buy a header, and a complete cat-back system, and scrap the stock exhaust.
Stan Moore
Feb 21, 2015 11:22 AM
godspeedcrv
17
Apr 29, 2009 03:23 PM
lmike6453
Aug 3, 2007 09:08 AM
DarKStaR5
Feb 2, 2005 06:19 PM
jimby452
May 13, 2003 11:03 AM
