Classic Hondas All Pre-1988 Hondas.
Honda CRX 86 Rear defogger keeps blowing fuse
Old Nov 17, 2009 | 04:06 PM
user 69782342442's Avatar
Icon2 Honda CRX 86 Rear defogger keeps blowing fuse
Honda CRX 86 Rear defogger keeps blowing fuse in my relay switch... what's possible? is it a bad relay switch? I've rated the terminal's voltage at about ~12 volts but it keeps burning out my 20amp fuse, I'm not sure if it's a relay problem or the wiring problem... On side note the connectors are fine that connects to the rear window's grid.. any ideas how I can keep the fuse from blowing and not "cheat the fuse by going more than 20 amps as it's supposed to be"?
Old Nov 17, 2009 | 05:21 PM
E-AT_me's Avatar
Default Re: Honda CRX 86 Rear defogger keeps blowing fuse
you more than likely have a wire exposed somewhere.
Old Nov 17, 2009 | 05:57 PM
Okay, I'll look into it... thanks for a suggestion.
eddygp
Honda CR-V & Element
Oct 2, 2010 07:57 PM
jdm206
11
Sep 17, 2007 11:59 AM
drtyhatch
13
Dec 14, 2005 04:43 AM
RiCeRTeG
Mar 16, 2005 04:19 PM
ModlesSI
Feb 22, 2003 03:16 PM
