shaking during acceleration driving me nuts!
Old Nov 16, 2009 | 02:41 PM
94civiccupew/b7's Avatar
Default shaking during acceleration driving me nuts!
ok so what's goin on is i have a shake from about 25-35mph. then it goes away. i've had my wheels balanced and i've changed my axles. that helped a little but it's still doin it. any ideas? wheel bearings maybe? thanks in advance
Old Nov 16, 2009 | 03:49 PM
Default Re: shaking during acceleration driving me nuts!
anyone?
Old Nov 16, 2009 | 05:12 PM
Big Dustin's Avatar
I have the same issue, it can be felt in the steering wheel like warped rotors kind of. Only, like the OP said, it is during acceleration, not deceleration.
Anyone have any ideas?
Old Nov 16, 2009 | 05:16 PM
i guessin you've checked your balance and your axles right Big D?
Old Nov 16, 2009 | 05:18 PM
93egSLEEPER's Avatar
where did you purchase you axles? have you checked you tie rod ends? wheel bearings? ball joints?
Old Nov 16, 2009 | 05:27 PM
i've changed my tie rod ends and ball joints recently. not my wheel bearings yet though. that's kinda what i'm thinking it is but i was just wanting to know if anyone else had any different ideas
Old Nov 16, 2009 | 05:39 PM
Big Dustin's Avatar
I actually have only owned the car for about 2 weeks. New wheels/tires will be on tomorrow, so that will answer that part for me. I was leaning towards wheel bearings because I believe my car still has the factory axles. I just dont hear any noises that would lead me to believe there is a bearing failure?
Thanks guys.
Old Nov 17, 2009 | 02:18 PM
any other ideas? or is the wheel bearings the only culprit left
Old Nov 17, 2009 | 02:42 PM
lopezchris21's Avatar
just taking ur car to get an alignment....
Old Nov 17, 2009 | 03:57 PM
92shade's Avatar
everything that has been mentioned and also check your mounts
Old Nov 19, 2009 | 06:21 AM
01silverstreak's Avatar
definately check yo mounts i bet the bottom driver-side is cashed out
Old Nov 19, 2009 | 10:19 AM
my two lower fronts have been filled with polyurethane, so i doubt it's that
Old Nov 19, 2009 | 10:28 AM
1grex's Avatar
Transmission or torque converter going bad, try a fluid exchange, you may get lucky
I just assumed automatic here, ignore if you've a 5sp of course
Old Nov 19, 2009 | 10:29 AM
CRX T-Si's Avatar
I had this weird shaking in my car before as well and I did the same thing you did.
Changed the axles, changed the brakes and gotten the wheels balanced as well. However it still comes and goes I can feel it when I accelerate the car. It also shakes a little during HWY at around 70mph as well, not alot but you feel it.
It turns out that my clutch was the problem where something was off balanced and when I accelerate it would shake. I changed the flywheel and clutch(ACT) and it was gone.
A flywheel, Disc, PP could go out of balance so that is something you may want to check out.
Old Nov 19, 2009 | 02:10 PM
lol. that's the best news i've heard. that's probably it then cause i know i need a clutch cause mine's chattering right now. i planned on buying it next month since i just finished paying off some bills. I know, well i hope it's not the tranny cause i just had it rebuilt this summer and there's fresh fluid in there. so sounds like it's the clutch. thanks everyone. i'll confirm if it's the clutch once i get it in
Old Nov 19, 2009 | 03:28 PM
g230sport's Avatar
sounds kinda like axles. but if you need a clutch might as well start there, if its still there after the clutch.
id be willing to bet an axle is bad
Old Nov 20, 2009 | 03:57 AM
1992hondacivicvx's Avatar
did u check the axel bolts they have to be there on tight cause they are probably loose
Old Nov 20, 2009 | 04:17 AM
EuroStar Tech's Avatar
New User
have you checked for bearing play at all?
Old Nov 20, 2009 | 11:45 AM
ramonjones16's Avatar
Yeah axles and maybe you have very shitty motor mounts and you motor is vibrating all over the place.
Old Nov 20, 2009 | 01:51 PM
b20_EM1's Avatar
Is your car lowered?
Old Dec 10, 2009 | 08:09 AM
okay. so i changed my clutch and flywheel last night and the shake went away. only problem now is my pedal feels to soft. i got a LSD Motorsports clutch. i bled my clutch, no bubbles and it's still soft. a guy at my work says it could be the slave cylinder but it was fine before the switch. so whatcha guys think?
Old Dec 10, 2009 | 09:21 AM
supra-n-civic's Avatar
i did an h2b swap in my hatch and witht the solid mounts i noticed this. i then discovered that becaseu my car was so low, i created axle bind. i had to lift it back up a bit to aleviate it. could be your issue if the car is really low
Old Dec 11, 2009 | 04:04 AM
so i found the culprit. the clutch master cylinder is leaking a little i'll get that fixed this weekend. thanks for the help guys
Old Dec 11, 2009 | 06:27 AM
CRX T-Si's Avatar
Glad everything is gonna be fixed man.
Normally it's difficult to explain how a clutch could cause this shaking but I'm glad you are the type that understands.
petrolhead89
Honda CR-V & Element
Jun 3, 2014 02:19 PM
jdmazm
Apr 28, 2005 07:57 PM
Outsane
Mar 19, 2003 11:57 AM
fire7882
May 15, 2002 09:00 PM
