Disc Swap on EJ6
Old Nov 16, 2009 | 10:58 AM
2tonecivic21's Avatar
Default Disc Swap on EJ6
I have a '98 Civic CX that I am doing a front and rear disc swap on. I have read the faq on complete rear disc brake conversion, but still alittle hazy on somethings. Do I need to get a 4040 prop valve that is abs, non-abs, or does it really matter? The master cylinder I was planning on buying is a 99-00 civic si which has abs, correct? So what is the correct m.c/prop valve combination I need to get? The rear disc swap is from a 2000 civic si if that helps with the confusion. Thanks in advance for the help.
FabianAra
Jan 30, 2018 08:02 PM
sinyce
Aug 2, 2016 10:48 AM
CWBETB
Mar 1, 2011 03:33 AM
JDMarshal
Suspension & Brakes
19
Oct 1, 2010 11:33 AM
xtreme412
15
Nov 28, 2005 12:16 PM
